Generally speaking, can Clevo P7xx compete with mini-itx desktop in anyway?
Discussion in 'Sager and Clevo' started by Ciellia, Dec 3, 2018.
  1. Ciellia
    Ciellia Notebook Enthusiast
    As the title says, just wondering whether Clevo P75x and P77x can actually offer same if not worse experience than a mini-itx desktop with similar spec. I am aware of the price difference, but what about in term of heat management and general performance? Does level of spec also make a difference? etc.
    Would love to hear your guys' thought.
    jclausius likes this.
  2. TheReciever
    TheReciever D! For Dragon!
    Depends on the Liter amount your allowing.
  3. Ciellia
    My mistake, let's assume compact model from 14 to 20 liters? Such as Cougar QBX or Silverstone RVZ03.
  4. TheReciever
    Well I suppose module aspect of desktops will take an edge from a lifespan perspective.
    For those that chase performance and willing to chase the limit of the platform the desktop will take a slight lead just because of better RAM selection. The other issue would be future compatibility of GPU upgrades. Nvidia has more or less abandoned the standard dimensions and AMD has no presence as of yet save for the WX 7100. That being said, as it stands the desktop vs laptop generation with 10xx GPU's are pretty close in performance.
    However obviously you would lose the portability of the laptop. You wouldnt be able to just put the laptop away and go, and bringing a desktop in a plane is a flip of the coin.
  5. Danishblunt
    Danishblunt Guest
    Mini ITX builds can have GPU's that are superior to the notebooks and have better cooling, not only that but mini ITX builds have the possibility of much better hardware, which makes the notebook an actual joke in comparison.
  6. John@OBSIDIAN-PC
    John@OBSIDIAN-PC Company Representative
    High Performance Laptops make sense if you need the mobility.
    Let me rephrase it, laptops are for users who need mobility and that´s it.
    It does not matter why you need the mobility, it does not matter the tasks, nothing else matters but this, if you need a Personal Computer to be used in more then a single location you *should* consider a laptop, not saying you *actually need* to buy a laptop, just saying you should consider it.
    But if you are going to use it *only* in one single location, then just build a Desktop with a form factor adapted to your available physical space and hardware needs.
    That should be the only thing that matters every time someone asks "Should i buy a laptop instead of a Desktop?".
    sicily428 and jclausius like this.
  7. Blacky
    Blacky Notebook Prophet
    The only way the two would be equivalent is if you somehow managed to tape a laptop LCD to the mini-ITX. If you could do that, then the ITX could compete with the Clevo, otherwise, the mini-ITX, while much better regarding performance and upgradability, will still need cables, displays, keyboards, etc. The biggest space waster is the display.
  8. jclausius
    jclausius Notebook Virtuoso
    If you use a 6-8 core LGA 1151 motherboard with similar GPU, memory, and add-on drives as the Clevos, you would get a slightly better build in the mini-ITX (due to better power and cooling solutions), but lose a bit of mobility, especially if you need to take a monitor everywhere.
    With that said, the problem is that in your question, you say 'similar spec'. A mini-ITX solution can do and support so much more. Money aside, with the proper motherboard, you could try to tame an 18-core CPU with a vapor chamber or a low profile CPU fan (or even possibly try a small water-cooler in the case of the Cougar QBX... great case by the way), run a pretty decent GPU, add 64GB of RAM, and to top it off use 5 or 6 drives, and all done with a BIOS that is blessed by the motherboard manufacturer.
    There is a bit of mobility issue (overall weight is about the same, and you need to bring wireless, travel-sized KB/mouse; plus the need for an external monitor; but save by not having to pack one or two large laptop PSUs). I don't know if travel by plane would be easy as they would try to boot it up, but how?? In any case, since I only need something that I fit in a gym bag, and travel by auto, I'm happy with this type of solution. More details about my mini-ITX setup can be found here - http://forum.notebookreview.com/threads/mighty-muscular-mini-itx-build.812322/
    Danishblunt likes this.
  9. Meaker@Sager
    I would not put a sff cooler on an 18 core CPU, that's not going to end well.
  10. Danishblunt
    Danishblunt Guest
    Jesus, thats a mighty mini alright :D
