Geforce 8600M GS - Force underclock? (Medion 96380)
Discussion in 'Other Manufacturers' started by Crogge, Aug 28, 2016.
  1. Crogge
    Crogge Notebook Consultant
    The usual Geforce "8" issue -> Overheating.
    The laptop runs fine as long as the GPU is running with the latest Nvidia drivers (August 2016) on the lowest clockrates, once it shifts up to higher clockrates the temps go beyond the 90°C limit and the laptop is overheating.
    Is there any possibility to FORCE the 2D mode / low clockrates (1. gear)? I know there are vBIOS mods which allow custom clockrates for each level, but I wan't to avoid any vBIOS mods on a soldered GPU.
    Is it possible to enforce the low clockrates (Powersave mode) via software level)?
  2. yotano21
    yotano21 Notebook Evangelist
    Have you made sure that the air vents are cleaned out.
