GE75 benefit from cooler pad?
Discussion in 'MSI' started by bm11, Dec 21, 2019.
  1. bm11
    bm11 Notebook Enthusiast
    Just curious if the GE75 benefits from using a cooler pad. They are pretty inexpensive, and it wouldn't be a big deal to run one on my desk where I'll be using it like a desktop. Is it worth adding one?
  2. specialist7
    specialist7 Notebook Evangelist
    So the benefit of a cooler pad isn't so much the pad itself but the fact that you're elevating the laptop and giving it airflow as where it would be restricted flat on a desk, table, or in some cases beds. The cooling will remain on the capability of the heatsinks and fans on the laptop. Elevating and giving it unrestricted airflow will benefit it more.
    For people who like using laptops on bed and not have a propup table then I would advise to use one of these as the openings and airflow help keep itself nice and cool.
    So yes the benefits you see are mostly if the laptop was restricted in the first place.
  3. bm11
    It was cheap enough, I ordered one. Came in today according to Amazon. I'll try it tomorrow and see if I get any benefit!
    Kevin@GenTechPC likes this.
  4. Kevin@GenTechPC
    How is it? :)
  5. bm11
    Still in the box. Waiting for my new desk to come in to set up my station. Desk should be here today.
  6. Aeronaut88
    Aeronaut88 Newbie
    I am using custom NotePal U3 for my 2070 9750h GE75.
    It does okay, corsair 12 cm high static pressure fans just under the intakes.
    I'd say the gain is about 2cels. under load.
    If you're going to spend like 30$, don't.
    Get a good paste and some thermal pads for that price. + get 5$ rubber stands to maximize intake.
  7. bm11
    Desk came in last night, set it up, did some gaming. Big difference in cooling, in my opinion. I need to do some more testing to see, but I went from max temps of 95c to 89c, which is a lot more than I saw from undervolting.
    I’m not sure if any of the other differences in setup helped also, but I went to an external keyboard and monitor at the same time.
  8. Aeronaut88
    Aeronaut88 Newbie
    External monitor may have helped.
  9. Kevin@GenTechPC
    Airflow, cooling pad, and change of cooling material will definitely help, beside undervolting.
    Papusan likes this.
  10. Hosom
    Hosom Notebook Enthusiast
    Sorry if i am a bit too late, but nope! For the GE75 there are no benefits at all... temperatures does not even see it by half a degree in by case. Tested on my own machine with a custom made cooling pad (strapped two high pressure fans under an old cooling pad support and wired them to a smartphone power supply).
