GE72VR 7R6 - Cooler boost physical button not working as intended.
Discussion in 'MSI' started by Rocktaze, May 19, 2017.
  1. Rocktaze
    Rocktaze Notebook Consultant
    Just received my GE72VR 7R6 and when clicking on the cooler boost physical button it takes up to 30 seconds before it reaches maximum fan speed.
    it slowly goes up to 6,000 RPM for CPU and 5,600 RPM for GPU fans.
    When i put my hand on the vents behind the laptop there a lot of air pushed out of the CPU vents but not so much out of the GPU vents.
    I've had 4 MSI laptop, 2 x GT62VR , 1 x GE62VR and this current GE72VR
    I've never had this problem before, normally when you click on the Cooler boost physical button it automatically crank all the fans to the maximum speed.
    Anyone have an idea what the problem could be?
    Thanks
  2. Djadit
    Djadit Notebook Consultant
    Maybe you can try update
    Ec bios
    Bios
    And checking the power config on control panel
    Fan passive/active
    Set to active
    Or reinstall dragon center
    Sent from my Redmi Note 4 using Tapatalk
  3. Rocktaze
    What i've tried so far :
    Update EC firmware multiple time
    Update bios multiple time
    Reinstall windows
    Reinstall Dragon center multiple time
