Gateway FX Disassembly Guide (Covers all 17in FX Notebooks)
Discussion in 'Gateway and eMachines' started by azrickster, May 18, 2009.
  1. TANWare
    Like any other older hardware this can happen, glad it all went well though.
  2. nindustrialny
    nindustrialny Notebook Consultant
    I have got a problem. I try to put it back after dissemblying but I don't remember the order of those two thin cables which go from LCD to Intel WIFI. black and white. Which is 1 and which is 2. can someone help?
  3. Audizzz
    Audizzz Notebook Consultant
    White =1, Black =2
  4. nindustrialny
    Can the author of the thread reupload pictures?
    I need to know where exactly the BIOS battery is. I have to replace it.
  5. TreeTops Ranch
    TreeTops Ranch Notebook Deity
    If you can download the service manual here: http://tim.id.au/laptops/gateway/gateway p-78.pdf you will find step by step instructions to replace the CMOS battery.
    You will have to remove the IEEE 802.11 wireless card in order to get to that battery.
Similar Threads - Gateway Disassembly Guide
  1. ieee488
    391
  2. SpongeBomb
    365
