Gateway FX Disassembly Guide (Covers all 17in FX Notebooks)
Discussion in 'Gateway and eMachines' started by azrickster, May 18, 2009.
  1. Audizzz
    Audizzz Notebook Consultant
    Thanks for the pic TANWare!!
    Now I know what to get
  2. TANWare
    NP, now if you stay C2D any CPU HS will be fine.
  3. Audizzz
    Im going to stay with C2D. I will get P-7908U from Aliexpress for $120
  4. TANWare
    It has been a while, did you get the main board? If so how did it go?
  5. Audizzz
    Im going to order MB next week, because this week Im moving..
    will report back, Thanks
  6. Audizzz
    I have received MB today. It took a while..
    TANWare:
    Do you remember what Soft I should uninstall in order to replace MB from 7811FX to P-7908U ?
    -Sound Drivers
    -Nvidia
    anything else?
    Thanks
  7. TANWare
    You do not need to uninstall anything. It will come back though and change the sound card drivers and may change the video driver. If you use MSI afterburner I would disable it until the new system booted.
  8. Audizzz
    P-7908U MB from Aliexpress + upgraded GPU heatsink is in my Notebook now- everything works fine.
  9. TANWare
    good too hear.....
  10. Audizzz
    The first MB that seller sent me was bad one -> I was able to boot, but could not install Nvidia drivers at all - Installation says that there is no nvidia chip available, also I had some artifacts on the screen.
    Then seller sent me 2nd MB - and its fine now.
