Gateway FX Disassembly Guide (Covers all 17in FX Notebooks)
Discussion in 'Gateway and eMachines' started by azrickster, May 18, 2009.
  1. Kamin_Majere
    Kamin_Majere =][= Ordo Hereticus
    Well it cost us the UnOfficial 68xx and 17x series sticky but Flipfire (being the awesomely Captain Awesome that he is) has sticky'ed this for us.
    I recommend renaming the Thread to:
    Gateway 17in FX disassembly Guide (68xx, 17x, 78xx series)
    As it does cover all of them equally.
    oh yeah +1 rep for the nice guide... better than my failed attempt with the laptops (still think they are glued together with blackmagic and hatred) :p
  2. RangerXML
    RangerXML Army of None [TRH]
    Really nice guild, great to have all of this in one central location. Now instead of being a and telling people to use google, now I can be a and tell people to simply look up.
    This is way better then the youtube video I was using before, +1 for you.
  3. azrickster
    azrickster Notebook Guru
    Unfortunately I didn't pay much attention to the express card cage, even when it fell off the first time I disassembled the laptop. I do recall there is a spring in there, maybe the spring just came loose or broke. I would go ahead and open it up, really not that hard. You may be able to order a replacement for the cage from Gateway if it can't be repaired.
  4. azrickster
    WOW, sticky'd - Thanks Flipfire!
  5. Nihilum13
    Nihilum13 Newbie
    This is awesome! Thanks!
  6. fire268
    fire268 Notebook Consultant
    Thanks for the great write-up. I tried the disassembly awhile back and got to the point of separating the mobo from the chassis and decided to turn back. I had too many parts lying around. This definitely helped me get to the GPU!
    + rep to ya...
  7. The_Moo™
    The_Moo™ Here we go again.....
    very good :) i like it when people take the time to create guide for other just because they want to help out
  8. roadsignologist1
    roadsignologist1 Notebook Enthusiast
    Why would you want to replace the GPU? I mean its a 1GB in an a notebook for christ's sake lol. Also what bluetooth module have people installed, where do I get one, how do I install it, and what about drivers? I looked in the other thread about this and there is SOME info but not everything I want. If someone can just gimme a break down of their setup and what they did to get it would be really appreciated. Thanks!:D
  9. The_Moo™
    the 1gb is nice but its not what makes the GPU fast...
  10. azrickster
    I do believe that Mr.Moo was refering to replacing the TIM on the GPU heatsink and not actually replacing the GPU. The GPU on the P7805-FX is not replacable as it is soldered to the MB.
Similar Threads - Gateway Disassembly Guide
  1. ieee488
    554
  2. SpongeBomb
    393
