Gaming PC (Skylake, AIR+QUIET) - Please advise
Discussion in 'Desktop Hardware' started by Terentino, Oct 22, 2015.
  1. Terentino
    Terentino Newbie
    Hi guys
    I am looking to build a new gaming PC and would need your advice on what components to use.
    The idea is I want a PC to last for 4-5 years without much investment in it. I am not a hardcore gamer but like to play and test the latest games. Mostly I play Starcraft 2 and Heroes of the Storm.
    Not interested in overclocking but would like to have this as an option (sometimes I like to test OC etc.)
    With this in mind I would like your suggestion on the following:
    Budget: ~2500$ (can be extended to 3000$ if needed)
    Hardware:
    CPU: Intel Core i7 6700K
    Mainboard: waiting for 2-3 suggestions
    Memory: 2-3 suggestions (should be 16GB at least, not sure if 2x8GB or 4x4GB mean much for performance)
    Video Card: Geforce GTX980Ti (suggestion on Brand and model. As quiet as possible but overclocked).
    SSD: should be M.2: Samsung 950 Pro or similar (256GB or 512GB)
    PSU: suggestions (modular, quiet, powerful but efficient).
    COOLING:
    CPU Cooler: Perhaps fan-less if case cooling is enough or something efficient and quiet.
    Case: mid or full tower (easy to work with, good build, keep inside cool and dust free, DUST FILTERS).
    That would be it.
    I know I am asking a lot but this is what I would like to spend money on.
    Thanks and looking forward for your suggestions.
  2. StormJumper
    StormJumper Notebook Virtuoso
    PSU: suggestions (modular, quiet, powerful but efficient).[/QUOTE]
    CPU: If you can afford it get the iNtel 2011v3 boards. Don't get AMD boards....Get iNtel CPU only. You want power iNtel is the way to go.
    Memory: I know DDR4 will be expensive but that is what is coming down the pipe.
    Video: GTX980Ti all the way...SLI if you can...you never know
    Monitor: Well this is tricky...If you want 4K that is connected through your GPU Video Display port. But I use DVI through my MSI GTX970OC 4G on a Dell 27" IPS and it works and look good. But man the IPS default setting is blinding in a dark room. Get a IPS if you can don't go lower then 23" if you can get a good one.
    SSD: 512GB Samsung or similiar..
    PSU: at least min 800Watts..I go 1000Watts if you can afford it. It will have to work less to keep your system going. With future expansion in mind. I have a Antec 750Watt and it is hold out fine.
    CPU Fan: I use the CoolerMaster 212 and it quiet enough for my needs.
    Case: This will depend how many HDD are you planning to put in it? I Finally went a Full Tower Corsair 750D and that was enough for my 16 HDD. But this was overtime that I need all this space. Otherwise a Mid Tower should be sufficient if your not addy more then 4 HDD into it.
  3. StormJumper
    CPU: If you can afford it get the iNtel 2011v3 boards or Skylake chipset. Don't get AMD boards....Get iNtel CPU only. You want power iNtel is the way to go.
  4. Terentino
    Terentino Newbie
    Thanks!
    We have so far:
    I won't be using more than the M.2 SSD or maximum another SATA SSD.
    For games I have decided to keep my current 1080p montior for at least 12 months and I will change it once the new Nvidia (Pascal) is out and get that one too :).
    DECIDED:
    CPU: i7 6700K + Noctua NH-U14S (should be enough for stock speeds and maybe a little of OC experimenting)
    RAM: G.Skill Trident Z 2x16GB DDR4-2800(CL14-14-14-35) or DDR4-3000 (CL15-15-15-35). Better go for lower timings or Mhz
    Video Card: GTX 970 (still need to decide what brand and model)
    SSD: M.2 Samsung 950 PRO
    NOT DECIDED:
    Motherboard: research / waiting for recommendations
    PSU: research / waiting for recommendations
    Case: research / waiting for recommendations
    Thanks again to all of you for your time and answers.
    If any ideas, recommendations pop up please let me know :)
  5. StormJumper
    Motherboard: Anything that is 2011v3 if you want or Skylake Chipset. I would choose MSI or Asrock boards.
    PSU: Any name brand that is from 800 to 1000 watts with 80% rating or higher. This will depend on what you plan to run if 2 SLI I go with at least 1000 watts this will prevent system drain and insure you got plenty of juice to spare-might be a tad much but I might go that route later next year as I currently have a Antec 750W and that is pushing 14 HDD/2 SSD plus 3 fans, 1 BD burner and a MSI GTX770OC 4G . That might be pushing it a bit far.
    CASE: This will depend if you go SLI or single GPU? But a midtower with expansion option for water cooling if you ever go that route would help. I would look at Corsair cases those have given me the most configuration.
