Gaming mouse for small hand?
Discussion in 'Accessories' started by Henris, Dec 22, 2017.
  1. Henris
    Henris Notebook Enthusiast
    What would be a good mouse with understated looks? Not too light . I have 17,5cm long and 8cm wide, palm grip. Thanks in advance
  2. kent1146
    kent1146 Notebook Prophet
    Without knowing more specifics, my go-to recommendation is the Logitech M705 Marathon Mouse. It's pretty much as close to perfect as you can get, for a general purpose mouse.
    Are you a gamer? Or is this for general / productivity use?
    Vasudev likes this.
  3. Henris
    Hello. I'm a gamer
    Vasudev likes this.
  4. Support.2@XOTIC PC
    The Razer DeathAdder is a fairly good choice anyway and fits within those dimensions, might be worth a look.
    Vasudev likes this.
  5. Henris
    Okay thanks
    Vasudev likes this.
  6. KLF
    I have Logitech G300s in my gaming computer. I'm also using older G300 in my second computer, it is same style mouse just older model. I like small ambidexterous mice. This works both palm and finger grip for me, depends on what I do.
    Vasudev likes this.
  7. Amina
    Amina Notebook Enthusiast
    I recommend checking out the Logitech G502, and the Logitech G900; they're quite effective for gaming sessions, and even for everyday use.
    Vasudev likes this.
  8. DukeCLR
    DukeCLR Notebook Deity
    I bought an EVGA torqx 10 on sale once and it was way too small for me, It actually gave me cramps in my hand so it sits in one of my boxes filled with spa=re PC parts.
    If you have a best buy around you can go try out a few, it's a personal choice which makes it hard give advice on.
  9. deanovip
    deanovip Notebook Guru
    I would look at RAT3 or higher very small and lovely hold. I since have bought two new mice and none of them are as nice to use.
    Sent from my SM-G950F using Tapatalk
  10. Support.2@XOTIC PC
    Very busy looking but definitely a smaller mouse, should work well.
