Gaming Laptop Help!
Discussion in 'What Notebook Should I Buy?' started by arezwwe, Jul 15, 2014.
  1. arezwwe
    arezwwe Notebook Enthusiast
    General Questions
    1) What is your budget?
    Roughly $2500
    15in - 17.3in
    Online most likely
    Not really
    I'd consider, but prefer new.
    Gaming
    I will travel with it often
    Yes, very demanding ones.
    3hrs or more
    this question is confusing but pictures will suffice
    11) What OS do you prefer? Windows (Windows 7 / 8), Mac OS, Linux, etc.
    Windows 8
    Screen Specifics
    12) From the choices below, what screen resolution(s) would you prefer? Keep in mind screen size in conjunction with resolution will play a large role in overall viewing comfort level. Everyone is different. Some like really small text, while others like their text big and easy to read.
    1920x1080
    13) Do you want a Glossy/reflective screen or a Matte/non-glossy screen?
    Doesnt matter
    Build Quality and Design
    No
    Between now and October
    4 years+
    Notebook Components
    I'd prefer 1TB HDD and 256MB+SSD
    Would like one, but not needed
    So far, I found this one, but not so sure about it.
    Aorus X7 Gaming Laptop - Newegg.com
    Could you guys recommend anything?
  2. Arcturus314
    Arcturus314 Notebook Guru
    Any chance you could fill out the sticky? It would be pretty helpful. Anyway the Aorus is a very thin gaming notebook, so it will have a higher temperature on the CPU / GPU which may cause damage over time. Here are some more traditional (thicker) gaming notebooks:
    -Alienware 17. This laptop is a bit expensive for what you get but I have heard it has very good build quality
    -Asus ROG G750JZ: More powerful than the Alienware, this has a 880M but and more RAM but you can't upgrade the CPU or GPU.
    -Sager NP8278-S: This is a rebrand of a Clevo laptop. It is the has the most customization options and is best for the money but doesn't look all that nice.
    -Dell precision M6800: Technically not a gaming laptop, this workstation has many costomization options, the best build quality of any laptop on the list, 3 year default warranty, and a really long battery life (5+ hours). Stick with the default Firepro M6100, you will get the same gaming performance as an 860M while having better drivers since it is a professional GPU
    Thin laptops: This laptops generate more heat and therefore will typically have a shorter lifespan:
    -Aorus x7
    -MSI GE60 and GE70 (17" and 15" variants)
    -Razer Blade
  3. arezwwe
    Thanks for the response. Sorry, I filled it out.
    These options are actually pretty appealing.
    -Asus ROG G750JZ
    -Sager NP8278-S
    What I don't understand is why the Sager is so cheap, it is alarming.
  4. Arcturus314
    Sager offers amazing performance for the price, but I have heard bad things about warranty and parts failing. I actually looked at the Alienware and Asus at Fry's electronics earlier today, and I found the Alienware to have far superior build quality. The Asus had a large amount of screen flex as well as flex in the keyboard and deck, while the Alienware felt nice to use and has no flex I could find. Actually Fry's is selling the top model Alienware 17 with GTX 780m for $2,198 great deal.
  5. arezwwe
    Wow, does sound like a great deal though admittedly the Asus you recommended has me in awe.
  6. arezwwe
    I was thinking of buying an "Open Box" laptop from Newegg but im weary.
  7. Katagon
    Katagon Notebook Deity
    Where have you heard that Sagers have bad warranty and part failure..?
  8. Arcturus314
    Two of my friends had their laptops fail on them; with one Sager refused to replace / fix the notebook because of a small scratch on the case.
  9. Katagon
    I haven't heard of issues like this, who did they buy from?
  10. Arcturus314
    One directly from Sager, the other XoticPC
