G75 many problems
Discussion in 'ASUS Gaming Notebook Forum' started by AmazingFactory, Jun 7, 2012.
  1. AmazingFactory
    AmazingFactory Newbie
    I bought a G75VW-DS71
    It arrived with a half-closed case, very loose screen bezel (plastic moulded incorrectly), broken sound, totally broken video and no backlight
    In other words completely useless
    Spoke to Asus support who were very familiar with this problem ... I was not the first ...
    It seems that a bad batch was fixed by hand and then sent straight to distribution with no testing ...
    Other rumours include G75 production temporarily ceased due to quality issues.
    On the ROG forums every second or third posting is a serious problem, some examples:
    660m gpu usage and framerate fluctuations
    ROG G75V - 660M does not spool up
    Ok seriously, what is the double beep!
    My new G75V and it's speed
    Would like some opinions, not sure if keeping G75
    On my 3rd G75 :(
    Asus G75 network adapter problem; can't connect to wifi.
    Asus G75VW - Black screen on boot up
    Horizontal lines/choppyness
    Live update killed my USB ports
    Network adapter gets disabled when using HDMI port
    Asus G55VW-DS71 Faulty or Fine?
    G75 GPU going to hot - Fan not working
    Red lines across the screen, now the G75 is dead
    G75VW Best Buy freeze up issues
    ASUS G75 no longer in production?
    And here is a typical experience (from another forum user)
    On my 3rd G75 :(
    Well so far this is my 3rd G75.....The first one the border around the screen was completely popped off, the 2nd G75 the subwoofer seemed like it was blown. Now im on my 3rd G75 and yesterday when i opened it the bottom panel to get to the internals was screwed in but half of it was popped off and im missing one of the rubber piece on the bottom......... Awesome QA Asus lol. I called asus to see if they would ship me ONE rubber piece just so i can put it on and thats it, but they told me that i would have to send in the entire computer.....So the guy gave me a website us.estore.asus.com which does not have the part, so that was a total waste of time.
    Now i dont know what to do, if i spend $1250 of my hard earned cash im expecting a product to be assembled correctly, especially a "gaming" laptop. I dont know if i should go back to best buy and exhange it again and open the new one right in front of them.
    So I am posting this to help any other potential ASUS "customers" from experiencing the same pain and hassle.
  2. Zymphad
    Zymphad Zymphad
    Yeah, could have told you how horrible Asus support is and their lack of quality control. This G73JH I think is the third one, I've had to return twice. Asus G Series blows. I like the design, it is quiet, but everything is just aggravating and terrible.
  3. Yiddo
    Yiddo Believe, Achieve, Receive
    +1 for showing this here in case others are making the decision.
    It would appear that sadly Asus have not sorted out their disgusting customer service issues then and intend to lose a lot more money again which they cannot afford to do when their whole key to selling is marketing because the hardware is certainly not worth the price.
    Embarrassing.
  4. Mobile Monster
    Mobile Monster Notebook Enthusiast
    I myself am the owner of the G75 and have not had those issues. Those issues seem to correspond with a Bad or Rushed Batch but does not indicate a Manufacturing Defect.
    It may be Bad Luck but at this point it's too early to say it has many problems. Remember that those with no problems don't post at all and those with problems do post. It's too early to diagnose it and say it's a Manufacturing defect or issue.
    Production hasn't temporarily ceased since I've seen retailers receive newer stock and quantity of the G75VW. Perhaps however they are focusing on Certifying the G75VW for Thunderbolt and releasing the 802.11ac variant as priority for production.
  5. PFL
    PFL Notebook Consultant
    Wow! How can they still be in business?
    I´m sorry to hear about the problems for G75 owner, and then I´m happy that I´ll probably keep my troublesome G73JH for years and years - WITH NO KEYBOARDLIGHTS, GRRRR!!!!
    But OK, I have the i7-920XM, hehehe!
  6. Yiddo
    This may indeed be true, but I have not browsed any other forum with so many posts about problems occuring and the OP has only had to brush over the ROG forum to be able to post numerous links relating to problems with the G75.
    Asus need to pull their socks up plain and simple, mistakes like this should never happen and no company should be giving any customer a 3rd model in quick concession to make up for the previous 2 defects its unheard of, not to mention they should have learnt from their mistakes with the numerous faulty models they produced in the past 5 years. They need to stop messing around with reverse engineering and built in motherboards and spend more time making the cheap areas of the laptop better quality while keeping the curves and the cooling which they are loved for and stick in a bloody MXM slot and access panel.
  7. Mobile Monster
    I agree with what you said Yiddo in it's entirety there. I have been reading about the G75 on the G5 Series sub-forum and it does seem as if there is issues with the G5 series but some of those are related to use of the Live-Update software update function and others seem to be un-related.
    The reason I went with the G75VW-DS72 over the GT70 0NC was due to the cooling system , the looks and also due to the noise level. The GT70 0NC has a similar setup but however I felt the 'Steelseries' keyboard was more of a gimmick with it's multicolor display. That was in addition to the issue of the Power brick (using 210 watts but only designed for 170/180) and the Virtualization disabled by default (which could be enabled later through a bios update).
    Personally I disliked the High glossy components on the GT70 as well. I felt it would attract too much fingerprints and dust. In addition the lack of a manual Eject (requiring use of the S bar) I felt was an oversight by the MSI engineering team. The mSata raid 0 configuration was a feature that drew me in but I felt it was insufficient storage space and I decided to go with the 256GB SSD on the G75VW.
    I wasn't fond of the cooling and exhaust location on the GT70.
    I used the following reviews to compare:
    Review MSI GT70 Notebook - Notebookcheck.net Reviews
    Review Asus G75V Notebook - Notebookcheck.net Reviews
  8. Yiddo
    In concept it sounded so good at release, the 660M is a very good card the 5/670M is a little bit extra no complaints and paired with an Ivy you think you are sorted but why do they stick with the integrated GPU but completely ignore the integrated card and do not include Optimus when it is a vital aid to mobile gaming. The RMA's I have had and read about make me shiver with anger it should be a thing of the past.
    The sad thing is it is not a good thing to see Asus failing by moving away I assumed that in 2-3 years something will come along that will eat up my Clevo and I will return but at this rate it scares me as much as the G73JH at release, it should not be about getting lucky as some mention you are paying out £1500/$ for something that should be a masterpiece for that sort of money :( some of the horror stories you read on here sometimes make my heart bleed I could drop kick my Clevo and then beat it to death with a stale loaf of bread and it would give me the finger and carry on functioning as normal haha ;)
    I have never been a fan of MSI so can understand your choice and with Clevo making a terrible move to refrain from BIOS releases for older models you are left with Alienware which I am sure they will be very pleased with the actions of other companies and although they are expensive they are very smart have a great warranty service and allow complete upgradability although I feel dirty saying it they have become a firm +1 in my books.
    Can only hope the majority are spot on and it is just a bad batch. Still worrying signs.
  9. WeeDv2
    WeeDv2 Notebook Consultant
    Mhhh intresting... i was looking into this thing... not good to hear this.
    Ill have to end up with clevo?!
  10. Zymphad
    Zymphad Zymphad
    You make it seem like a bad thing. Clevo while maybe louder is much more compact. The G series 15" from Asus is bigger than any other 17" and the G73jh I have now is monstrous. No effort at all for portability, my 5870m doesn't even down lock properly. I have to force it with vbios changes. Its pathetic.
    Clevo while louder actually fix their issues. Compact design. Better cooling and have optimus and enduro enabled. Easier to upgrade, access components, far better hardware and options!
    Sent from my SGH-i937 using Board Express
