G73jw vs G53jw --- Opinions.
Discussion in 'ASUS Gaming Notebook Forum' started by fgocards, Sep 5, 2010.
Which laptop would you buy?
  1. G73jw!!
    48.0%
  2. G53jw!!
    52.0%
  1. ibraveheart
    ibraveheart Notebook Evangelist
    Display: 15.6" 1920x1080 FDH Color-Shine (Glare-type)
    Dimension & Weight: 15" x 11.42" x 2.36" (W x D x H) 7.5lbs
    If you want my Specs
    Asus G53Jw-A1
  2. madrabbit711
    madrabbit711 Notebook Consultant
    I'm going to get the G53SW this weekend to replace my very much flawed m15x-R1.
    After a long debate with myself I think this is the best choice as there may only approx. an inch more in added depth and width for a 17' monitor, but the same specs and resolution why not just get the smaller version? If you had to sacrifice on specs and resolution then sure the G73JW is a whole different decision.
    The only thing against the G53JW over the G73JW is aesthetics in terms of bezel size and disassembly. I also think you won't nice 1 inch of size on either model as it's hidden behind the screen, unlike other laptops which have hinges pivoting on the edge of the laptop body.
    I also think that the ASUS G53SW will just barely fit in my current Samsonite satchel-type bag, based on a scale 2D cardboard cut-out I made using the G53JW dimensions (yes I'm that sad!). An inch more on-top of this i.e. the G73JW and it won't fit.
    The GenTechPC review on YouTube has both of the G53JW and G73Jw side-by-side at the start for a comparision:
    YouTube - Asus ROG G53JW nVidia GTX460M Gaming Notebook overview
    In addition I found this useful website which may help:
    Sized Up: Asus G73JW vs Asus G53JW vs Precision M6500 vs MacBook Pro 17 vs Studio XPS 13
    I still think a card-board cut-out is the way to go though.
    I think you'll also just have to accept that the G53JW is more a 16' laptop with a 15' monitor. If you can move past this then it's the best choice IMO.
    Lastly as crappy as the m15x-R1 is, it's made me appreciate 1920x1080 on a 15' screen! Being my first laptop, I 'ummed and ahhed' over this prior to purchase but haven't thought negatively about it since...especially when you realize how useful it is to have 2xA4 pages side-by-side on a 15' laptop for work.
    Now if only they made the G53SW with slightly smaller and with better port positioning...
  3. JediTim
    JediTim Notebook Enthusiast
    Where were you able to find a G53SW? I have not seen any posted on the Reseller websites so far? This is the model I plan on getting as well.
  4. twixter
    twixter Notebook Enthusiast
  5. Voodooi
    Voodooi AFK for a while...
    Definitely the G53JW/SW. Problem-free, unlike the 73-series, where it's "laptop-roulette".
  6. JediTim
  7. madrabbit711
    Yep sure was:
    https://www.mln.com.au/product/?itemID=837&typeID=23#
    I should get it in 2 weeks hopefully.
    However I'm based in Melbourne, Australia and so is the 'MLN' store where I placed the pre-order.
    A lot of other Australian resellers are stocking it though:
    ASUS G53SW laptop notebook - G53SW-HD-SX020V - G53SW-FHD-SZ010V - 15.6 inch gaming laptop with GTX 460M
    http://www.lmc.com.au/products/Notebook_Computers/Asus/574864/ASUS_Notebook_G53SW-FHD-SZ010V_Intel_Core_i7_2630QM/8Gb/1Tb/BluRay_Combo/BT/1.5G_NV_GTX460M/Webcam/15.6%5C%22LED/Win7_Home_Premium_64Bit
    Asus G53SW-SZ010V - $2,069.10 - Centre Com
