G73jh built in mic issue
Discussion in 'ASUS Gaming Notebook Forum' started by joshr, Jul 27, 2010.
  1. joshr
    joshr Notebook Enthusiast
    Hello, the built in mic next to the camera in my g73 doesn't seem to work quite right to say the least. When I went to test it by listening to it, it makes a loud high pitched sound until I disable the device. Anybody have any helpful advice?
  2. windyvincent
    windyvincent Notebook Enthusiast
    Maybe low the Microphone boost can do better.
    In the CP - Realtek HD Audio Manager.
  3. joshr
    Even after changing the boost it still doesn't function properly.
  4. moral hazard
  5. joshr
    Is there anyway to fix this issue or even to somehow remove the mic itself. I put snow leopard on but the mic gets feedback as you say and therefore I had to disable the audio driver. But I doubt we can go into the details of my hackintosh project, so I will refrain from further details on OSX. I really need to solve this issue either by fixing it or removing it from the system. Since it is built into the monitor I'm not quite sure how to physically disable it, any help would be appreciated.
  6. moral hazard
    Here is what I did in XP:
    Right click on volume (in the task bar)> Adjust Audio Properties>Audio>click on volume of sound recording>mute all.
    Not sure how you do that in any other OS.
  7. joshr
    So is this a problem that everyone has or just me?
  8. <MarkS>
    <MarkS> Notebook Village Idiot
    I'm not sure what the problem is.
    If it's feedback, you shouldn't have the mic input playing simultaneously on a playback device that the microphone can pick up the output from - that's what causes feedback.
    Try
    1) Right click the little speaker icon in the taskbar notification area and choose "recording devices"
    2) Double click on the microphone device
    3) Click on the "Listen" tab
    4) Make sure the "Listen to this device" checkbox is unchecked.
  9. joshr
    When I click listen to this device that's when it happens, I'm not quite sure that I understand why it happens. Forgive me, but I don't understand why this does what it does. Will the mic work correctly under normal use?
  10. <MarkS>
    That's why it should be unchecked :)
    Source of the feedback:
    1) Sound goes in microphone.
    2) Sound is amplified (made louder)
    3) Louder sound comes out speaker
    4) Go to step 1
    To prevent feedback, break any part of the loop described above. For example, use headphones to listen - you'll hear yourself in the headphones but the microphone won't pick up the sound from the headphones.
    You can also test if the microphone is working using the Windows Sound Recorder (Start/All Programs/Accessories/Sound Recorder).
