G73 Wireless Module
Discussion in 'ASUS Gaming Notebook Forum' started by Sniper101, Dec 8, 2010.
  1. Sniper101
    Sniper101 Notebook Guru
    Has anyone here replaced their wireless module on the ASUS G73? If so what did module did you replace it with? Is there anyway I can find a higher quality LAN Module?
  2. kaiten
    kaiten Notebook Guru
    I used the Intel 6200 as a replacement wifi card. It is way better than the stock one I had.
  3. Sniper101
    Where did you buy the card from? and was it a straight forward install?
  4. puterg33k
    puterg33k Notebook Consultant
    I seem to be the only one having problems with Intel 6250+
  5. kaiten
    I purchased mine on ebay for around $20. Its pretty straight forward, just open the hard drive panel and you can see it. The drivers themselves will be available on asus's website or intel's. I would check to see what you have first. If you have the Atheros card then I would recommend the change. If you have an Intel, you might just want to keep it and see if you can find updated drivers. I have the A1 version.
  6. puterg33k
    Apparently the conflict was with the NEW intel 6250+ drivers and ESET SMART SECURTY 4. Huh...
  7. Sniper101
    Would I be better off with the 6200 or the 6300?
  8. <MarkS>
    <MarkS> Notebook Village Idiot
    Compare.
    Note: The 6200 has two antenna connections. The 6300 has three antenna connections but only two antennas are installed in the G73. Many have used the 6300 with two antennas and some have added an antenna.
