[G701vi] How to connect 5.1 speakers?
Discussion in 'Asus' started by winyl, Jul 8, 2017.
  1. winyl
    winyl Notebook Enthusiast
    With G701vi you get only two minijack outputs. So how to connect 5.1 speaker which hace 3 minijack inputs? All the 70x and 80x have diffrent chasis design with no ODD drive and two minijacks, difrrent from G75x when you get ODD and 3 minijack outs.
    Or there is diffrent way to connect 5.1 speaker to G701vi? I would not like to chane my 5.1 set 'cause G701vi need digital out or usb c connection to speakers.
  2. namaiki
    namaiki "basically rocks" Super Moderator
    A 5.1 capable USB sound card would probably do the trick.
  3. winyl
    That is just great. G75x model had the ability to connect 5.1 speaker and G70x does not have this. Is this model is supposed to be worse?
  4. Support.2@XOTIC PC
    You should be able to get 7.1 and 5.1 surround with a setting change in the Realtek audio manager with the single audio cable.
  5. ashknani
    ashknani Notebook Consultant
    can u please tell me if u have this laptop with the 120hz ips display ? model AUO119D ?
