G53 behaves weird after being resumed from sleep mode
Discussion in 'ASUS Gaming Notebook Forum' started by nealloy1981, Mar 18, 2012.
  1. nealloy1981
    nealloy1981 Notebook Evangelist
    when at night i feel sleepy i don't bother to shut down. i just close the lid straight which lid it to sleep mode. but next day when i come back from my job i find my laptop alright just for first few minutes. after that it starts behaving weird, like mozilla firefox is not responding, windows task manager is not opening. mouse courser is waiting sign. comes back to normal but again in waiting mode. and when i manage to restart, it goes up to the logging of screen and never shut down and eventually got BSOD. is there anyone can help me please. this is really annoying and time consuming. i really like sleep mode work properly.
  2. HavokD
    HavokD Notebook Guru
    do you have hibernate enabled? do you use hybrid sleep?
    We can start from there to try and solve the problem.
  3. nealloy1981
    What is hibernate enabled and hybrid sleep? sorry for my ignorance but would be glad to learn.
  4. JOSEA
    JOSEA NONE
    open your power plan from control panel, are you using one of the ASUS power plans or a standard windows plan (balanced, power saver, or High performance)? Verify your lid close action also.
    If you have any settings that will cause the computer to hibernate, Reset the : http://www.sevenforums.com/tutorials/819-hibernate-enable-disable.html Follow option 1 - /Disable it , reboot and enable it.
    ~~~dstrakele makes a great point (shutdown is the quick fix) - I had a similar issue, could be bad ram also, eventually Tijo told me to make sure my SSD never went to sleep, this solved it for me.
  5. dstrakele
    dstrakele Notebook Consultant
    You can configure your lid in Power Options to shut down, rather than sleep, which would solve your problem immediately.
    Alternatively, you can troubleshoot which application or driver is causing your system to lock up on resume from sleep or hibernate. Examine the Events in the Windows System and Application Event Logs to see if they can indicate the problem driver or application, or at least point you in a troubleshooting direction.
    If this problem is a recent development, try using Windows System Restore to restore your system to an earlier time before the issue appeared.
    Simply type or cut and paste your question into the search box of your browser and the answer will be revealed, grasshopper.
    No disrespect to you, @nealloy. It is one of the best ways to learn...
  6. nealloy1981
    i am using ASUS power4gear plan. and my lid close action both in plug in and battery is set to be sleep mode.
  7. JOSEA
    JOSEA NONE
  8. nealloy1981
    i have changed my lid close action to hybernation mode. now while watching movie last night, i have closed the lid along with mozilla with some tabs. now when resumed its giving me that problem and eventually restarted by pressing the power button.
  9. dstrakele
