G-Sync problems. AW 18 GTX 1070
Discussion in 'Alienware 18 and M18x' started by Raja786, Jan 17, 2019.
  1. Raja786
    Raja786 Notebook Consultant
    Right I have a Alienware 18 with a 1070 which I upgraded to with modded drivers and am only able to use through SG mode. I’ve connected my laptop via DP to the monitor which is a Acer Predator X34P. I am unable to use g-sync as in the nvidia control panel there isn’t an option for display. I have the latest intel drivers installed. Even when I’m overclocking refresh rate to 120Hz in the OSD and go into intel options max refresh rate is 60Hz. Anyone know how I can get around this and be able to use g-sync?
  2. marcomarc
    marcomarc Notebook Enthusiast
    I have an Alienware 18 with 780m SLI and Intel 4600. Dual boot Win10 and Kali linux
    Strangely, on Windows 10 i cannot get more than 60MHz refresh even with Nvidia. On Kali linux i can get 120Hz even with the Intel 4600.
    199,94Hz exactly.
  3. Raja786
    Nice. 60 FPS @ 3440x1440 sucks tbh
  4. marcomarc
    What i mean: The refreshing difference (in my case) looks like to be an OS problem and not a driver problem or hardware problem.
    You should boot on a live linux and make a test
  5. Raja786
    I wouldn’t know where to start tbh.
  6. marcomarc
    I have an Acer GD245HQ connected. But with this Acer monitor i cannot get more than 60Hz too. Maybe because i have HDMI connection and not DVI
  7. Raja786
    Yes on mine hdmi only supports upto 50Hz. DVI for higher resolutions.
  8. ssj92
    ssj92 Neutron Star
    You can't use G-SYNC using SG mode. Only PEG would allow these features.
    One of the limitations using Optimus.
    M18x-oldie likes this.
  9. Raidriar
    Raidriar ლ(ಠ益ಠლ)
    bingo
  10. Raja786
    Thanks for clearing that up. So am I limited to 60Hz then even though I have a monitor capable of 120Hz?
