FZ-Q1 , FZ- Q2 tips, tricks, and mods
Discussion in 'Panasonic' started by Shawn, Mar 16, 2019.
  1. SHEEPMAN!
    SHEEPMAN! Freelance
    True that....
  2. Shawn
    This was on a FZ Q2 but I bet it applies to a FZ Q1 also.
    Just got it with w10 installed. brightness was wonky.
    Dim in BIOS and ok brightness in w10.
    I tried F keys which had zero effect.
    w10 showed the slider at max brightness.
    I was a bit baffled.
    It appeared the w10 install was a generic install.
    I have the factory recovery image so I installed it.
    The brightness flickered several times during the install. After the install was done, the brightness was normal again, even in the bios screen.
    I think the factory install changes brightness settings at the BIOS level while the generic install can't change those bios level settings.
  3. Shawn
    Q2 has wifi module soldered on, like a 3E does.
    Blair, can you add Q2 to the title of this thread?
    Thanks
    (Done)
    UNCNDL1, toughasnails and evenflow153 like this.
  4. Shawn
    Q2 camera test on W10.
    Decent quality for a webcam.
  5. mklym
    mklym Notebook Evangelist
    Yes, the image quality is decent for a webcam, very little pixalation, the most notable is the 'EXIT' sign.
    Considering that you are wearing an awesome tie-dyed t-shirt, rainbow frame glasses and have a 'KEEP IT REAL & REFRESHING' sign over your right shoulder, you look way too serious, almost like a mug shot or a passport photo. :D
    I hope the day gives you something that makes you smile. :vbthumbsup:
    UNCNDL1 and Michael AU like this.
  6. Shawn
    If the day doesn't, the psychiatrist IS trying to.
    UNCNDL1, Michael AU and evenflow153 like this.
  7. evenflow153
    evenflow153 Notebook Consultant
    Seems like you like to take photos at that place :D
Similar Threads - tips tricks mods
  1. evenflow153
    364
  2. KING19
    15
    1,075
