FZ-G1 true serial with gps installation
Discussion in 'Panasonic' started by towelie, Apr 12, 2018.
  1. towelie
    towelie Notebook Enthusiast
    [​IMG]Is it possible to have both at once? The gps antenna is on a small board where the serial port would be.
    I want to get a serial port upgrade kit but i cannot find much info or even pictures of it.
  2. Shawn
    towelie likes this.
  3. towelie
    Didn't find an answer in the thread you provided but if i can find a kit for a reasonable price i will give it a try
    Update: Noticed the pictures you added on that thread, they were very helpful thanks!
  4. towelie
    I'm still interested in acquiring a serial kit so if there is anyone here willing to sell me one or exchange it for a GPS kit or bridge battery kit send me a message!
  5. Shawn
    They do make usb to serial converter cables.
    SHEEPMAN! likes this.
  6. towelie
    I used those before but the usb port on the fz-g1 is a bit tricky to use because of the cover, i have a feeling that over time it will get worn off or damaged.
