FZ-G1, MC7750, and GSM questions
Discussion in 'Panasonic' started by interestingfellow, Apr 3, 2019.
  1. interestingfellow
    interestingfellow Notebook Deity
    I'm having some issues finding clear answers to a few questions and lots of luck finding contradictory answers.
    Which software package should I load onto my G1 to operate this card?
    Will this card do Tmobile GSM? How?
  2. Shawn
    interestingfellow likes this.
  3. towelie
    towelie Notebook Guru
    T-mobile
    1900 MHz - B2 - 4G LTE/4G HSPA / 3G (UMTS/HSPA) / 2G
    1700/2100 MHz (AWS) - B4 - 4G LTE/4G HSPA / 3G (UMTS/HSPA)
    1700/2100 MHz (AWS) - B66 - 4G LTE (extension of band 4)
    850 MHz - B5 - 4G LTE
    700 MHz - B12 - 4G LTE
    600 MHz - B71 - 4G LTE
    MC7455 (Max LTE Download speed 300Mbps Upload 50Mbps)
    LTE-A: B1, B2, B3 ,B4, B5, B7, B8, B12, B13, B20, B25, B26, B29, B30, B41
    WCDMA B1, B2, B3, B4, B5, B8
    MC7355 (Max LTE Download speed 100Mbps Upload 50Mbps)
    LTE :B2, B4, B5 ,B13, B17, B25
    WCDMA B1, B2, B4, B5, B6 MHz
    MC7700 (Max LTE Download speed 100Mbps Upload 50Mbps)
    LTE: B17, B4(AWS)
    WCDMA B1, B2, B5 MHz
    GPRS/EDGE B2, 1800, 900, 850 MHz
    MC7750 (Max LTE Download speed 100Mbps Upload 50Mbps)
    LTE: B13
    LxEVDO and LXRTT: 800/1900 MHz
    No GSM bands
    EM770U (Huawei Max Download speed 7.2Mbps Upload 5.76)
    If i were you i would order this MC7455, there is no better cellular card for mini-pcie.
    https://www.ebay.ca/itm/Sierra-Wire...018267?hash=item23add11d5b:g:JhAAAOSwGsdbmjEk
    It's not cheap but at least you won't need to upgrade later on.
    UNCNDL1 likes this.
  4. interestingfellow
    I do have in my possesion a "Dell Inspiron Mini 1012 Genuine Mobile Broadband 3G 4PRVK EM770U HSPA Module GLP" for Tmobile
    Os there some g1/panny restriction preventing me from using that?
    I'm not sure why I would have to have more than 3g for my needs?
    I have it in my cf30 but never pursued setting it up.
  5. towelie
    I know there is some Ericsson cards for Toughbooks, never heard of Huawei variants. Give it a try, maybe it will work. You might encounter issues with the wwan id though.
    As content on internet is getting heavier and heavier, eventually 3g will feel slow.
    I added a EM7455 to my CF-20 and the speeds are fantastic.
  6. towelie
    I just added your card to the comparison post above. I can't find any information about someone trying this Huawei card in a Toughbook or any other Panasonic computer. Beside being available to purchase and specifications, there is not much community involvement behind it. It is similar to the MC7700 but does not support LTE and 3g/4g download speeds above 7.2 Mbps(MC7700 should get to at least 42 and possibly up to 100).
  7. interestingfellow
    As it turns out, I also have an MC7700 (gsm 3g) and a MC5720 (sprint)
    I will report back.
  8. User32
    User32 Notebook Deity
    Ericsson cards are for Europe, i'm using a F5521GW from a 19 Mk5 in a Precision M4300 as we speak.
  9. interestingfellow
    Is there a table or single source/doc explaining the "optional kit configuration" settings?
