Fujitsu T902, T901, T900 Wacom driver in another Wacom laptops. Help!
Discussion in 'Fujitsu' started by boombyte, Mar 7, 2019.
  1. boombyte
    boombyte Notebook Enthusiast
    Hello.
    Does anyone know is it possible to install the original driver (or mod) to an another non-Fujitsu Wacom tablet\laptop?
    Why? There is 2-button stylus that is amazing and can replace mouse at all. Most of newly pens have only 1 button(.
    Tried a standard installation but nothing works. Just empty install. I'm in despair(.
  2. Starlight5
    Starlight5 W I N T E R B O R N
    @boombyte did you try just installing generic Wacom driver and setting up the pen there?
    Are you sure your other laptop is also EMR? Did you try RadialMenu to assign additional button function?
  3. boombyte
    I tried drivers for Win7 64, Win10 64 from Fujitsu site. They dont work\install.
    What is EMR? What is generic driver?
    I know about radial menu but it must be assigned on that one button (right click). So when I used my T5010 (little later T902) I assigned Pop-up menu (I like it 100 times more than the radial menu) with 2nd button that T5010-T902 stylus has. And It was great. Untill a new one comes. They almost all have 1 addition button (or even no buttons at all).
  4. boombyte
    Found 3 drivers from Wacom.
    2 work, 1 half-works--it offers to choose 2nd button but the button doesnt work. (an original stylus from t902 etc). And touchscreen disabled by driver.
    The t902 driver (for Win7 64) says "there is no supported tablet". The t902 driver for Win10 64 install and works. But offers only one button. Bad(.
Similar Threads - Fujitsu T902 T901
  1. vjosesan
    777
