Fujitsi Amilo Xi2550 running with 8GB
Discussion in 'Fujitsu' started by grunnsat, Dec 16, 2012.
  1. grunnsat
    grunnsat Notebook Consultant
    As I wrote in my previous thread on using Windows 7 64 bit on the Xi2550, I would also try to install 8GB of memory. I can now tell you that I have installed it, and it works fine. So instead of the max. 2GB Fujitsu claimed it would support, you can use 8GB! The only problem is that 4GB DDR2 modules are not really cheap compared to 4GB DDR3 modules. It will most likely work with other older laptops too if they have the Intel 965 chipset!
Similar Threads - Fujitsi Amilo Xi2550
  1. vorob
    2
    847
