FSB Increase and overclocking
Discussion in 'Alienware M15x' started by MrMogwai, Feb 17, 2020.
  1. MrMogwai
    MrMogwai Notebook Evangelist
    I've read the entire SetFSB thread, cracked a version of SetFSB (not ashamed to say it, it's been an abandonware for at least 7 years, for anyone interested there are online code generators for the software to work to bypass the obnoxious hardware ID check), but I seem to have one of those un-setFSB-able mobos. With unlocked A09, 940XM, Win10 and so on, I am unable to increase the clocks, and I was unable to exceed my CPU above 29/28/27/26 or 27/27/27/27 with multiple TDP/TDC configs. I believe I've checked all the mobo options in SetFSB version 2.3.178.134 and have abandoned almost all hope, but wanted to ask the final question - is there a way to set it any higher, with another software, or with a certain config? Can I exceed 133MHz?
  2. Raidriar
    Raidriar ლ(ಠ益ಠლ)
    You do understand that there is no front side bus on the M15x, right? Starting with nehalam and onwards, fsb was deleted and replaced with qpi (quick path interface). Which you cannot overclock, only raise multipliers on the xm class CPU. Only M17x R2 has some weird implementTion that allowed to raise cpu by 5% tops (similar to BCLK overclock).
  3. MrMogwai
    Ok. This I didn't realize. Thanks for clearing that issue. The next one is, is it possible to increase base multipliers? Both Throttlestop and Intel XTU have very trimmed options
  4. Raidriar
    Raidriar ლ(ಠ益ಠლ)
    Only for 920XM and 940XM
  5. MrMogwai
    @Raidriar, sorry to spam this in an old thread, but could you possibly pm me? I can't contact you directly, and I've got a project I would like to discuss. Thanks in advance!
  6. Raidriar
    Raidriar ლ(ಠ益ಠლ)
    I do not accept PMs because I got tired of people spamming my inbox for tech help. Make a thread in the Alienware subforum for whatever it is you wish to accomplish.
  7. MrMogwai
    Thread posted in Alienware 14. Check it out, would you kindly :)
  8. Nathaniel Krentz
    Nathaniel Krentz Newbie
    What code gen did you use I'm having a hard time finding one?
  9. MrMogwai
    Bah, it's been a year now, I can only recall that the keygen was online on a site, not a downloadable one. I'll try to find it, but can't guarantee results
    Edit:
    Found a script for unlocking
    https://pastebin.com/XgWThYd9
    moral hazard likes this.
  10. Nathaniel Krentz
    Sweet, thanks! Quick question tho, how do you use the script? I see it needs to be used as an html but I'm not sure how to go about doing that.
