FSB downclock mod on the intel GL960 and GL40 --- useful info for PLL Modders
Discussion in 'Hardware Components and Aftermarket Upgrades' started by naton, Aug 21, 2011.
  1. videogame57
    videogame57 Newbie
    He says he was probably remembering wrong and that it was actually just a high end Duo.
    Also, I got the E6500, flashed the latest BIOS, and installed the QX9300 and I have an issue. In the BIOS it shows 4 cores, but in Windows I only have 2 cores and half the cache available. The E6500 never officially shipped with a Core 2 Quad, but it's sister laptop the Precision M4400 did, and is identical aside from better GPU options.
  2. remdale
    remdale Notebook Evangelist
    I told you:)
    Because the other 2 cores are disabled. As I have just found out, there are 2 versions of E6500. With built-in Intel graphics and the other one hosts Nvidia (which is M4400 sister board as you are saying). The former board has GTLREF_2 not connected, so only duals can work. In the latter case, quads should work fine.
    So I guess your board has just Intel graphics. If so, you will have to do the mod.
