FSB downclock mod on the intel GL960 and GL40 --- useful info for PLL Modders
Discussion in 'Hardware Components and Aftermarket Upgrades' started by naton, Aug 21, 2011.
  1. naton
    naton Notebook Virtuoso
    Can you explain the steps involved in changing SetFSB registers and what registers to change. This is useful for both the T6**0 and T4*00 CPU series.
    What works on the GM45 might also work on the GL40 and GL960. Those with the GL960 should be able to use this registry hack for 533 -> 667, 667 -> 800 and 533 -> 800, and those with the GL40 can do 667 -> 800. That means that I can run my T4200 at 2.4GHz instead of 2GHz without worrying that it will lock at x6.
  2. niffcreature
    niffcreature ex computer dyke
    No, its not a registry hack. Its still dependent on PLL. I meant the "PLL control registers" in the 'diagnosis' tab of setfsb.
    In other words, I was simply stating you can use CPUs with different FSBs to identify PLL control registers and overclock when the PLL is unsupported. I think this is what setPLL is like?
    Wouldn't help if it was TME locked.
  3. moral hazard
    That's a good technique.
  4. crayonyes
    crayonyes Custom Title! WooHoooo !!
    I wanttttttttttt
    will X9100 + throttlestop work with unlocked multiplier on 965 chipset :D
    somebody pleaseee try.
    meanwhile I'm bombing rep now, y'all so superr!
  5. niffcreature
    Yes, we've established it will probably work now.
    I tried my q9200 on the XPS m1730. No go! :(
    Fortunately I believe both Dell and Acer have a history of locking out quad cores and extreme CPUs even on pm45 notebooks.
    Also, I think I attempted to dowclock it to 667mhz instead of 800. So I'll try it again after I try a t9400 or something.
  6. naton
    I've tried two CPUs (FSB 667 and 800) on a laptop equipped with the GL40 and two versions of SetFSB; I don't have any hex numbers in the "PLL Control Register". Does it meant that I can't overclock (i.e push the FSB up)?
  7. niffcreature
    You have to click "get FSB". otherwise yes you cant overclock or if it says PLL read error or something like that.
  8. moral hazard
    You should also try using RWeverything to read the PLL registers (click on the clock generator).
  9. naton
    When I press on "get FSB" I got an error: "PLL Byte Error". I didn't had much luck with RW. I don't remember what was the error though. I have to try it again.
  10. jedisurfer1
    jedisurfer1 Notebook Deity
    anyone have info or tried it on a Lenovo T61 or T61p
