FSB downclock mod on the intel GL960 and GL40 --- useful info for PLL Modders
Discussion in 'Hardware Components and Aftermarket Upgrades' started by naton, Aug 21, 2011.
  1. remdale
    remdale Notebook Evangelist
    Just to shed a lot of light on this topic.
    I have a Santa Rosa platform that is PM965. I've installed a 1066MHz CPU and modded just 1 pin of PM965 to make it think it's working with a 800MHz. Now my PM965 is working at 1066 fine, no problem. My idea is that any chipset that officially supports 800MHz CPUs can work at 1066 as well. So I think this topic on downclock for Santa Rosa and Montevina platforms is useless already:)
  2. Silko
    Silko Newbie
    Please i need u metod for modifid my lapto give me
  3. User32
    User32 Notebook Deity
    So wait, I break off one pin on a X9100 and that allows me to run a cheap Extreme Edition CPU in my M4300?
  4. remdale
    What's your laptop?
    My HP HDX9000 is running X9100 fine, so your M4300 should work be working fine too. But you will have to get a 800MHz RAM stick first, if you don't have it yet. What is your config now?
  5. Silko
    Silko Newbie
    [QUOTE = "remdale, post: 10902744, miembro: 692711"] ¿Cuál es tu computadora portátil?
    Mi HP HDX9000 funciona bien con X9100, por lo que su M4300 también debería funcionar bien. Pero primero tendrás que conseguir una memoria RAM de 800MHz, si aún no la tienes. ¿Cuál es tu configuración ahora? [/ QUOTE]
    My lapto is Emachine e528 i have one processador x9100, i buy he for paypal and not working for pll dowload i testest other procesador 1066Mhz and used mod he is working only 800
  6. Silko
    Silko Newbie
  7. Silko
    Silko Newbie
    My computer is Emachine e528
  8. remdale
    Your chipset is GL40. FSB:RAM divider now is 1:2. You will have to buy 1066 RAM to make it work because of the divider.
    Do you have schematics for your laptop? I tried to find it, but no success.
  9. Silko
    Silko Newbie
    I not have one
  10. User32
    DDR2-667 with 800 CL3 timings flashed with SPDTool, so it should work in theory.
    FYI Precision M4300 = Latitude D830
