FS: P150EM Parts - excellent condition
Discussion in 'Computer Components' started by Beefsticks, May 7, 2018.
  1. Beefsticks
    Beefsticks Notebook Consultant
    Clevo P150EM / Sager NP9150 parts. Parting my trusty P150EM. I used it as a desktop replacement. It was always on a cooling pad, and connected to an external monitor and keyboard. Keyboard and LCD are in mint condition with hardly any use. I kept the power brick positioned with open airflow to keep it cool. I used IC diamond thermal compound since day 1, and adjusted my pipes to drop the temps about 20C for the operating life of this unit. The screen has 1 very small scratch about 3mm long, but is %100 functioning.
    Cheapest actual shipping will be charged.
    OEM P150HMBAT-8 5000mAH Battery (full capacity, under 100 cycles) - $30
    OEM PCP Group 180 Watt power brick - $30
    4 x 8GB G.Skill DDR3 SODIMM 1333MHZ RAM - $150 (SOLD)
    Wide gamut matte LCD with %95 sRGB color gamut for editing (has 1 very tiny nick on it, %100 pixel function. Minor cosmetic scratching on plastic back.) - $60
    OEM Sunrex Backlit keyboard (mint condition) - $30
    Speaker cover with power switch cover - $12 (switch cover is a little wobbly but works fine)
    GPU Cooling pipe assemblies, heatsinks, and fan. For AMD7970M and compatible. Will need some replacement thermal pads or grease to fill gaps - $30
    Intel 3610QM CPU - $50
    CPU pipes and cooler - $30
    Motherboard (PREMA BIOS) - $175
    3RD speaker/'subwoofer' - $10
    Bottom hardware vent cover - I dremmeled some of the fan grille open to drop temps by 5C... was too restrictive - $20
    Bottom hardware bay cover (sloppy dremel job opened the vent a little for a -5C temp drop) - $15
    Optical bay HDD caddy for SATA HDD w/ bezel - $15
    Bare chassis (top, or bottom, or both) Top $35 - Bottom $45 - Both - $60
    Parts will come with their respective screws.
    View attachment 158543 View attachment 158544 View attachment 158703 p150em013_1.jpg p150em014_1.jpg
  2. Beefsticks
    Ram is SOLD
