FRIENDS, Solution for Heating and Thermal throttling has been found!
Discussion in 'MSI' started by cuneyt1984, Nov 7, 2021.
  1. cuneyt1984
    cuneyt1984 Notebook Consultant
    Hello friends, I have succeeded as a result of my research. And I want to share this achievement with you. As you know, MSI laptops generally have overheating problems. I also wanted to solve this problem. I ordered my Cooler MasterGel Maker (Cpu and gpu) and Cooler master Icefusion V2 (other components) thermal pastes. Honestly, the result was better than I expected. I definitely recommend you guys. It's a bit of a tough job. You have to be careful. But you will get a good result if you replace the thermal paste. MSI has been a Chinese brand for years. However, the cooling performance of MSI laptops is poor, except for the GT series. Therefore, I recommend replacing the thermal paste.
    I have been using the laptop for a long time. As a result, there was no increase in temperatures.
    There was no pump-out effect. You can safely try it for laptops.
    Stock Paste.
    Cooler Boost is on.
    Stress Test
    CPU: at 95 degrees At 3.5 GHZ. There is thermal throttling. 60 watts of power.
    GPU: 71 degrees
    After the thermal paste is renewed.
    Cooler Boost is on.
    CPU: 4.00 GHZ at 80 degrees. No thermal throttling. 80 watts of power.
    GPU: 68 degrees . The results are truly impressive.
    Note, I did not remove the battery. However, after disconnecting the laptop from the adapter, I did an EC-Reset by pressing the power button for 15 seconds. And I pressed the battery reset button.Use the blue triangle apparatus in the picture when turning on the device. Start from the side of the device to open the back cover.And I just used a napkin and my fingers to wipe it off, no liquid.
    for CPU and GPU
    https://www.coolermaster.com/catalog/coolers/thermal-grease/new-mastergel-maker/
    for other components.
    https://www.coolermaster.com/catalog/coolers/thermal-grease/ice-fusion-v2/
    Rooter1234 likes this.
  2. NeXt3R
    NeXt3R Notebook Evangelist
    in oem is thermal paste on VRM ? and on VRAM :eek:
    I thought it was a good idea just for CHOKES ,.,not more
    thermal paste name ?
    edit
    only what I mean is, I tried it with TG kryonaut and I almost burned my laptop! on CHOKES the paste is probably fine,.,. but on MOSFETs you want something special "pads or special paste"
    at least TG kryonaut - not works on MOSFETs + OC
    any thermal pads is more stable results
    vram ? - better pads for sure "easy way kill this components"
    carefully .,.,.good luck ;)
  3. Raid0ss
    Raid0ss Notebook Enthusiast
    Excellent results, the question is: how long will it last? I don't think it's pump out effect proof (or almost)
  4. Raid0ss
    Using a practically liquid thermal paste is normal that it was going to fry. Using a viscous thermal paste solves the problem.
  5. hacktrix2006
    The fact you have only 2 heat pipes on CPU heatsink for the CPU, your going to run hot all the time. On Intel BGA they should be using 4 or more.
    The other issue is you have a thin laptop which also adds to the heat issue, if you want the overheating to stop its best to get the GT series if your sticking to MSI.
    Even an Clevo DTR with a Desktop CPU gets hot with certain loads its the way Intel chips run yes we all used to joke about ATI/AMD for being a house warmer but that's now the only crown Intel managed to keep after taking it.
    As for the VRM's and Chokes if you can safely pad them else your going to need something along the lines of K5 Pro or something like it to fill the gap.
    Sent from my SNE-LX1 using Tapatalk
  6. NeXt3R
    hacktrix2006
    for this cooling 80W - 90C is very nice results ,.,.still is this THIN notebook and thermal paste
    weird will be setting MSI - target 150W above ??? :D
    MSI "PROCHOT" tcc offset - 94C or HK cpu -99C
    but my recommended is max 90C usage or lower for thermal-paste
    GPU ? "old rtx -85C max" .,,.for new not have idea
    //edit
    + FAN CURVE is critical "oem starts full spin - 94+" for coolerbooster .,.otherwise it probably wouldn't even make sense [​IMG]
    example
    20-30-50-60-100-100 - full fan speed around 90C
    small hint for better results "prevent paste drying / full use your cooling" ;)
