Fps drop at 75°C (thermal throttling?)
Discussion in 'Alienware' started by RafaelZBr, Jul 3, 2018.
  1. RafaelZBr
    RafaelZBr Newbie
    [SOLVED]
    https://www.reddit.com/r/Alienware/comments/8vorr4/fps_drop_at_75c_thermal_throttling/?
    SPECIAL THANKS FOR SHASHANK066 AND ALEXNVIDIA
    i made a post in reddit, but was recommended to post here, so...
    I have my aw17 r4 with the 7820hk and an 1070 for -+6 months, in my first 2/3 months i had no problem, gaming at 60°c and good fps (even did some overclocking), but after this 3 months my laptop start giving me some fps drops (was at 80fps drops to 1 and comes back to 80, every ~30s) just in Forza horizon 3 and the division pubg (just gpu intensive games), the room temperature was about 30c (welcome to Brazil) but if i turn on the a/c (drop the room temperature to 19c)this stop, but from that day an now was getting worse, now even with tge a/c on, undervolted and underclocked i get fps drops, the laptop temperature settle in the 75-79c, idk if this is thermal throttle or any other problem, any thoughts?
    i really don't know if is thermal throttle, because if i use an fps lock and the temperature drops to 71°C, the fps drop stop (but playing at 30fps gives me kinda of a motion sickness) (and uses just 50% of the gpu)
    Solution that i already tried:
    Drivers (gpu, intel thermal something)
    Undervolting gpu and cpu
    Underclocking cpu
    Place the laptop higher on the desk for more airflow
    Formating windows
    Bios update (i can't downgrade because a lock in the bios 1.23)
    Uninstalling the GeForce experience
    Getting older drivers
    Disable kionix i/o (what this do?)
    Updating windows (insider)
    Downgrading windows
    maximum performance scheme on windows
    some tests that i did
  2. Nachomonster64
    Nachomonster64 Newbie
    did you manage to fix this Im having the same issue around 70c on my Alienware m14x R2
  3. RafaelZBr
    RafaelZBr Newbie
    shashank066 and c69k like this.
