fparts.txt not found when flashing A14+
Discussion in 'Alienware 17 and M17x' started by Grant B Gibson, Jun 27, 2018.
  1. Grant B Gibson
    Grant B Gibson Notebook Deity
    I'm just trying to flash to the unlocked BIOS, but it spits out this redundant error, even when the file is right there, next to all the other files, in the C:/ folder.
  2. TheReciever
    TheReciever D! For Dragon!
    What BIOS are you currently on?
  3. Grant B Gibson
    A14 I flashed back from A15
  4. TheReciever
    That flash was successful?
    I ask only because others that had tried back flashing were having trouble, Ill ping the others that have more first hand knowledge of this process and hopefully they might have seen this scenario.
    @Striker1234 @MahmoudDewy @Ashtrix and maybe @woodzstack might have seen something
    And of course @javers who also contributed quite a bit to our machine.
  5. Grant B Gibson
    It seems to be, the laptop is working fine and has been for about a month, Ill try reflashing A14 and the A14+
    A14: http://www.dell.com/support/home/us/en/04/drivers/driversdetails?driverid=rp3cc
  6. TheReciever
    It might help speed things along if you're comfortable providing a screen shot of your root directly, just so they can have a baseline to work off of
    Also check out the emergency backflash procedure in case things go awry
  7. Grant B Gibson
    Wdym root? Assuming you meant C:/ Folder contents?
    here: https://imgur.com/a/5RaBDrK
    I've tried renaming it to fparts.txt, that didn't work either
  8. TheReciever
  9. Grant B Gibson
    edited above post
  10. TheReciever
    Sorry I cant help further, I didnt have that issue when I flashed my machine. All I can do is direct to whom may know
