Found: Cheap Blue-Ray for P-6831FX and P-6860FX (PATA)
Discussion in 'Gateway and eMachines' started by Tybalt39, Jan 3, 2009.
  1. Tybalt39
    Tybalt39 Notebook Evangelist
    Just a quick note...
    If anyone is interested, the Optiarc PATA Blu-Ray drives have recently been going for less than $100 on eBay. At least three have sold this week. I bought one on Amazon for $160 a couple of weeks ago (should have checked eBay).
    There are older posts in this forum detailing how to install it (takes about five minutes).
    If this is old news, sorry...
  2. Kamin_Majere
    Kamin_Majere =][= Ordo Hereticus =][=
    with out a 1920x1200 or 1650x1080 screen upgrade a blue ray drive is largely a waste i would think.
    Its a good deal on the drives, but largely a waste of money unless your just trying to whole heartedly embrace the format
    For those that do get the drives, be sure to get a player/codec pack that is capable of actually playing Bluray disc's
  3. Tybalt39
    True...
    I bought a WSXGA+ replacement screen the same week I bought the computer. That's the lowest resolution I would recomend for Blu-Ray playback.
    The Arcsoft package seems to be the best bang-for-the-buck in playback software (unless you already have Nero 8, then buy the plug-in).
  4. Zakattack423
    Zakattack423 Notebook Consultant
    I hear that the P series has been about the same with the measurements, so could I put this in the P-7805u too?
  5. Diablo
    Diablo Metalhead
    except for the fact that the 7811 (for sure) 7805/7807 (you would have to check for certain) use SATA drives...
  6. Danja
    Danja Notebook Evangelist
    What about 171/172/173 FX? SATA or PATA?
  7. Bungles
    Bungles Notebook Guru
    nvm :( not a blueray
  8. BlackSheep5
    BlackSheep5 Notebook Consultant
    I'm pretty sure we have the PATA
    I have the 1900x1200 screen and Cyberlink PowerDVD 8 Ultra so NOW there is a cheap Blu-ray drive :D
  9. BlackSheep5
    Got any links for these? I have been searching and havn't found any yet.
    Other than this one and its not cheap
    http://cgi.ebay.com/Sony-NEC-BC-550...1QQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247
  10. BlackSheep5
