For work, good build quality
Discussion in 'What Notebook Should I Buy?' started by fullsleeves, Sep 12, 2017.
  1. fullsleeves
    fullsleeves Notebook Consultant
    Looking for a new laptop for work. I would be taking it daily to and from the office. Thus, I'd like something that has good build quality above (almost) all else. Doesn't have to be a "rugged" notebook, but I'd like to be able to not worry when its in my rolling bag.
    I was looking between the XPS13 or the Lenovo X1 carbon.
    I do not need incredible specs, though these seem to come pretty well equipped anyway.
    General Questions
    1) What is your budget? $2500 CAD
    c. Thin and Light; 13" - 14" screen
    3) Where will you buying this notebook? Canada
    a. Like: Dell, Lenovo
    b. Dislike: Apple
    5) Would you consider laptops that are refurbished/redistributed? no
    6) What are the primary tasks will you be performing with this notebook? light duty: word processing, internet, research, reviewing video
    7) Will you be taking the notebook with you to different places, leaving it on your desk or both? traveling daily
    8) Will you be playing games on your notebook? If so, please state which games or types of games? No
    9) How many hours of battery life do you need? ~4
    10) Would you prefer to see the notebooks you're considering before purchasing it or buying a notebook on-line without seeing it is OK? doesnt matter
    11) What OS do you prefer? Windows (Windows 7 / 8),
    Screen Specifics
    12) From the choices below, what screen resolution(s) would you prefer? Keep in mind screen size in conjunction with resolution will play a large role in overall viewing comfort level. Everyone is different. Some like really small text, while others like their text big and easy to read. (Scroll down to see screen resolution information.)
    na
    13) Do you want a glossy/reflective screen or a matte/non-glossy screen? (Scroll down to see explanations.)
    doesnt matter
    Build Quality and Design
    14) Are the notebook's looks and stylishness important to you? not really, build quality more important
    15) When are you buying this laptop? now
    16) How long do you want this laptop to last? 3 years
    Notebook Components
    17) How much hard drive space do you need? Do you want a SSD drive? 128gb is plenty
    18) Do you need an optical drive? If yes, a DVD Burner, Blu-ray Reader or Blu-Ray Burner? no, but would be nice
    END COPY
  2. jwolf7722
    jwolf7722 Notebook Deity
    Thinkpad or Precision models have good build quality. I prefer Lenovo thinkpads build quality a little better. Used Lenovos t470 for a month. It was built like a tank.
  3. ZaZ
    Honestly, most notebooks will live out their lives giving faithful service, so I wouldn't fret about it, but there's no accounting for fate. On occasion, sometimes "well-built" notebooks break. Whatever you get, you may want to consider adding accidental and on-site warranty coverage since you have a healthy budget. Then it'll be fixed quickly regardless of how it's damaged.
    penguinslider likes this.
