For atheros pcie ethernet controller v2.0.2.6 check cable connection exiting intel pxe rom no bootable device error
Discussion in 'Alienware 18 and M18x' started by chetanappu007, Jul 14, 2012.
  1. chetanappu007
    chetanappu007 Notebook Enthusiast
    Hi guys,
    I have an alienware m18x r1,intel i7 2670,16gb ram,dual nvidia 580m graphics, 64gb samsung 830 ssd and 500gb hdd.
    I tried to replace the 64gbssd with a sandisk extreme 240gb ssd. The windows installation was very slow and after it finished installing and the system restarted i got this error
    " for atheros pcie ethernet controller v2.0.2.6(09/28/2010)
    check cable connection!
    PXE-MOF:exiting intel pxe rom.
    no bootable device-insert boot disk and press any key".
    I tried to boot with my old 64 gb ssd but it showed the same error.
    Both the samsung ssd and sandisk ssd are getting detected in bios but i keep getting the same error.
    i am using AHCI mode.
    PLease help out.
    Thanks in advance
  2. Kev-Kanuk
    Kev-Kanuk Notebook Guru
    You could try checking your boot order in the bios, try either the SSD first or the CD/DVD first then the SSD.
  3. chetanappu007
    tried that too...did'nt work
  4. steviejones133
    steviejones133 Notebook Nobel Laureate
    Sounds like your machine is trying to boot from a network instead of the drives. Are you 1000% sure its set properly in bios and you have exited and saved changes made? - you could try resetting bios settings to defaults, also you could do a power drain (remove battery/AC and hold down power button for 10-20 seconds) and maybe remove the CMOS coin cell battery to reset it and then put it back in.
    Just a thought but have you made sure all drive connections are secure? - also, were the OS's installed whilst in AHCI or have you switched to AHCI afterwards (if so, they wont boot). If you do reset bios to defaults, make sure your Sata operation in bios matches the mode used when installing the OS.
    Those would be the things I would check first as there should be no reason why your original SSD wont boot.
  5. chetanappu007
    I am sure that i installed the OS in AHCI mode and the boot priority was also the hard drive. I have tried to reset the bios but it shows the same error. However, ill still re do everything from the start and will also try removing the cmos battery and check if the drive connections are secure.
    I have a question...lets say i want to use both my ssd's the 64gb and 240gb ones. In which mode should i install the OS? Should it be AHCI or RAID?
  6. steviejones133
    I always use RAID. Even if you aren't creating a raid array, it makes sense to do it that way as if you add a second drive in the future and want to raid them together, it's a much simpler process. You can then simply create an array with Intel RST and extend the volume to setup your new array - if you installed under AHCI, you would have to re-install the whole OS etc....a lot less troublesome to use RAID in the first instance as it would save you a load of hassle later on down the line.
    Note that you wouldnt want to raid 0 your existing SSD's as you would lose ALOT of valuable SSD space because if they are not the same size drives, they would default to the lowest size. This is because of "raid striping" and it needs to be done to equal size drives - as your smallest drive is 64gb, you would end up with a 128gb (x2 64gb) raid array instead of having 304gb (64gb + 240gb) available.
  7. chetanappu007
    If i use the 2 ssds i should use RAID and when i use one ssd and one hdd i should install os in AHCI mode.
    Also which sata port , 0 or 1 supports sata3.0....or do both the ports support sata 3.0?
    I tried what you suggested and tried a fresh installation on the 240gb ssd in ahci mode by resetting the bios. After the initial setup finishes and the system restarts, i get the starting windows screen without the windows splash...then after a few min the screen goes blank. I have waited for 15min to see if something happens, but the screen still is blank. Now i tried to switch off the system and restarted and i keep ending up with a blank screen after the starting windows screen. When i start it in safe mode it says setup cannot finish in safe mode.
    Any ideas what the problem is?
    i tried the fresh installation on 64gb ssd an d it works fine.
  8. steviejones133
    Tried to help with my answers as above. What I would try and do is install from the Win7 Disc by inserting into the optical drive, shutdown, reboot...enter bios....change Sata operation to RAID...save and exit....immediately hit F12 for the one time boot menu.....select boot from cd/dvd and see how windows installs with that......it should install fine....fingers crossed.
  9. chetanappu007
    Thanks for explaining....anyways i tried to insatll os in RAID mode and after the installation i was greeted with a new error.
    Windows has encountred a problem communicating with a device connected
    Says i have a faulty hdd or cd rom
    File:\windows\system32\winload.exe
    Status:0xc00000e9
    unexpected i/o error
    I plugged in the sandisk ssd into my desktop and it worked fine...i formatted it and plugged it into the laptop and tried again to get the same error.
    Any more ideas?
  10. chetanappu007
    I have also checked the firmwRe version and it is up to date.
