Foam dam barriers for Liquid Metal safety insurance guide.
Discussion in 'Hardware Components and Aftermarket Upgrades' started by Falkentyne, May 21, 2018.
  1. jl1728
    jl1728 Notebook Enthusiast
    That looks pretty similar to what I used. I still had to slice my foam in half, which took a few tries. Used double edged razor blades and sawed them slowly.
    binchunsu likes this.
  2. Dr. AMK
    Dr. AMK Living with Hope
    Nice find and looks good for me as well.
  3. Falkentyne
    Falkentyne Notebook Prophet
    jaybee83, jclausius, Papusan and 3 others like this.
  4. bdashg2
    bdashg2 Newbie
  5. Falkentyne
    This depends on the denseness of the foam you buy.
    This foam isn't dense at all so the thickness is fine.
    The denser the foam, the less thick it has to be.
    You don't want resistance on your heatsink pressure.
    Papusan likes this.
  6. bdashg2
    bdashg2 Newbie
  7. Temp1234453
    Temp1234453 Notebook Consultant
    Would you use LM on a laptop that moves twice at day,everyday?
  8. jaybee83
    jaybee83 Biotech-Doc
    depends on the heatsink fit, kind of movement, LM application, measures taken against potential spills....
  9. Sentential
    Sentential Notebook Evangelist
    I wouldn't, the more I used LM and understood it the less I liked it and eventually decided that if the stock Shin-Etsu doesn't work well enough and the heatsink doesn't supply enough even pressure to use a PGS pad you should buy something else. All LM does is mask a fundamental engineering problem that eventually will lead to some kind of catastrophic failure when the LM shifts or dries. It's not a matter of IF it's a question of WHEN.
    tilleroftheearth likes this.
  10. minc3
    minc3 Notebook Consultant
    I still have some Kryonaut lying around. Is it possible for me to use Kryonaut paste as the dam? Was thinking of applying it around the die on top of kapton tape. Wondering whether this will seal it completely from any air or whatsoever.
    EDIT: ordered K5-pro since i noticed that K5 pro is a lot thicker and hopefully its gonna provide some nice seal
