Fn keys not working
Discussion in 'Asus' started by ericlala, Feb 2, 2006.
  1. ericlala
    ericlala Notebook Consultant
    everytime i start up in windows, i get the error about Hcontrol.exe... my Fn keys worked before but i think after some driver install from the asus disk was what made it stop working... help anyone?
  2. ru1thirst
    ru1thirst Notebook Consultant
    Sounds like a problem with the ATK-100 drivers. Update or reinstall from the Asus site and that should fix it. The Hcontrol.exe is one of the 17 files in the update.
  3. AuroraS
    AuroraS Notebook Virtuoso
    Ditto! Re-install the ATK0100 drivers and all SHOULD be well...
  4. ericlala
    no luck, still getting error on start up and Fn keys not working. I'll give it one more go.
    Also, does the fan ever go off? I have undervolted to 6x @ 0.700 and 14x @ 1.07 and my cpu idle temp is still around 45-47C
    it might help to add that i have a z63a
  5. AuroraS
    Once the fan starts up... it will stay on indefinitely (in most cases).
  6. PROPortable
    PROPortable Company Representative
    Actually........ Asus' ATK drivers include all theremal management drives (like the ATK is supposed to) -- but it also controls all the hotkeys and function keys.....
    If you're still getting an error - then something's up.. I'd restore the system back to before you had the error because reinstalling it isn't getting rid of it. I guess you could always try to delete them first and then reinstall........ but trying a restore would be pretty easy......
  7. ericlala
    ok thanks guys i got it working
    i uninstalled it then restarted windows, then it detected new hardware and i just let it automatically update it and it works
    however, my touchpad scroll doesn't work... when i press on the strip, it shows the scroll icon on the pointer but it doesn't move the page up and down
  8. AuroraS
    Are you using Mozilla Firefox? If so, update your Synaptics touchpad drivers from www.synaptics.com
  9. ericlala
    u guys rock :)
  10. AuroraS
    Tell us something we don't know :cool:
    Haha..j/k
    Just glad we can help!
