Flush USB 3.0 Expresscard Adapter
Discussion in 'Hardware Components and Aftermarket Upgrades' started by damaph, Jul 26, 2010.
  1. Krane
    Krane Notebook Prophet
    There are not precision devices. They are inexpensive stamped product that try to fill a gap for the precious few users that still use them. They're remnants of a never quite highly utilized slot. The likelihood of you getting one that works is about 50/50. If you get any better than that, consider yourself lucky.
    Starlight5 likes this.
  2. MarkraM
    MarkraM Notebook Geek
    :S
    seems like your advice is something like "Buy the cheapest you can find and...good luck!" :D
    i'll see what to do, thank you for your feedback.
  3. alexhawker
    alexhawker Spent Gladiator
    Or look for a seller that seems to have a decent return policy.
    Sent from my iPad using Tapatalk
  4. MarkraM
    After some web searching i found a card that seems a little better (at least from the opinions i read about it) than other cheap products.
    It's this Targus product: Targus Europa | ACA34EU – Targus USB 3.0 Express Card Adapter
    It has one usb (enough for me) and one DC Power jack.
    Can anybody tell me what's the point of having a DC Power jack? i'm not an expert, but the usb should already provide the power for a 2.5" Hard Drive...
    Am i Wrong?
    Does anybody know this card and can share an opinion? :)
  5. alexhawker
    Depends on the hard drive model. The more portable ones receive power over USB; others require power separately.
  6. 83bj60
    83bj60 Notebook Evangelist
    I second the previous opinion. I have an Iomega eGo and without external power is flaky at best. it comes with a second USB plug to get extra power.
    The power jack is meant to be connected to another USB port as a source of extra power, for those hard drives that take more than what the card can natively supply and come with only a single connector.
    As for the AKE being being 'cheap'... I have two of the 54mm model and they both work flawlessly. The only problem is the USB connector, it tends to come off. I punched some dents on the outside casing to retain the connector better, and it works well (see picture).
  7. MarkraM
    Thank you for sharing!!
    At first i was looking for an AKE card too, but than i found the opinion of a guy that bouth it and coulnd't get it to work on the laptop model i have too.
    So i searched for different models.
    Forgive me but i didn't understand if your final opinion on the product i linked is positive or not, do you think that a Usb + DC power jack can be better than 2 Usb port??
    To take advantage of the DC power jack i think i need a cable like this, right?
    But my question is...
    Which is the difference with a cable like this? (in case i buy a 2 usb card of course.)
  8. MarkraM
    I know this, but i think that a separate power source can also be provided from a second USB port, using a Y-Cable, right?
    what i do not understand is if there's an advantage in having a DC power jack over a second USB port in the card.
  9. MarkraM
    i did some more research about those cards and i ended up with this:
    The expresscard connection is not able to provide the 5V that's usually given by a usb port.
    That's why, with expresscard adapters, the connection is not always stable when they have to power up a 2.5" hard drive.
    That's also the reason why in some expresscard adapter you can find a DC Power jack. It can be connected to another usb (also 2.0) port of your laptop to reach the needed voltage.
    Now... my last question is:
    Can the same result be achieved also with an expresscard adapter that has 2 USB port but no DC power adapter?
    If i connect one of the 2 USB3.0 of the card to an usb2.0 of my laptop... will the other usb3.0 port have the "plus" voltage?
    If yes...it doesn't make sense to buy a card with a DC Power adapter i think...
  10. maxslo
    maxslo undefined
    Ok, to everyone with spring-load expresscard, if you are having issues with the card not sitting in the slot, here is what i did to permanently fix it wihout the toothpicks or anything.
    When i opened the laptop for cleaning and repaste i removed the spring from the slot, so now the card stays in the slot wihout any issues :)
Similar Threads - Flush Expresscard Adapter
  1. luisxd
    11
    1,634
