Flush USB 3.0 Expresscard Adapter
Discussion in 'Hardware Components and Aftermarket Upgrades' started by damaph, Jul 26, 2010.
  1. xla
    xla Newbie
  2. davidricardo86
    davidricardo86 Notebook Deity
  3. HeXenEoN
    HeXenEoN Notebook Enthusiast
    I am using AKE BC618T Express card. Everything is fine except when the system wakes from sleep it is showing an error "Power surge on Hub Port"
    I have updated the driver but the problem still persists.
    Could some one help me?
  4. Woonder
    Woonder Notebook Enthusiast
    You bought an Express Card which has NEC/Renesas PD720202 inside. It's really sad because as I know there is no solution for this issue. I received two cards some time ago and had to send it back to the the seller. I wrote about this issue here .
  5. Woonder
    I have received this item today. I think, it is the best choice for notebooks which have a few USB ports by default (like my 12" HP EliteBook). It works well without any issues. I tested it on my external WD My Passport (WD7500KMVW inside), which heavily used by me every day.
    AKE ExpressCard based on Fresco Logic xHCI chipset (3x USB 3.0 ports)
    (Tested on HP 6560b using Windows 7 Enterprise SP1 x64)
  6. Woonder
    I decided to test my external HDD at home, using AKE BC618T (uPD720200 inside) on my HP 2530p. Result is below.
    AKE ExpressCard BC618T based on NEC/Renesas chipset (2x USB 3.0 ports)
    (Tested on HP 2530b using Windows XP Professional SP3 x32)
  7. Woonder
    And I will test my external HDD using the new Fresco adapter at home soon. Test result will be here.
    (Tested on HP 2530b using Windows XP Professional SP3 x86)
  8. dragon434
    dragon434 Notebook Enthusiast
    Can anyone give me the drivers for the AKE BC618T 54mm card? and also how to correctly install it
    ive tried a million drivers and there not working:mad: :mad: :mad: :confused:
  9. Woonder
    To install a driver successfully you should know the model of chipset installed inside your adapter. Try to install this one .
  10. $n!pR
    $n!pR Notebook Guru
    I bought the AKE eSATA/USB 3.0 Expresscard/54 and connected it with a Western Digital 2TB Caviar Green drive in a Vantec NST-330SU3-BK NexStar exclosure and I get 58MB/s write speeds. I think the write speed is 100MB/s when connected to the computer through sata.
    EDIT: For some reason I get completely different results using the Crystal Disk Mark tool vs. Explorer. Must be burst speed...
    eSATA
    USB 3.0
