Flashing P775DM3 GTX 1080 to work in P870TM1-G
Discussion in 'Sager and Clevo' started by Hterag, Sep 17, 2018.
  1. Meaker@Sager
    Nvidia updated the boot code, as tested in my DM3 cards trying to boot in the TM.
    Hterag likes this.
  2. rainer124
    rainer124 Notebook Guru
    HteragNotebook Enthusiast
    question. why does it not work in TM-p870tm?
  3. rainer124
    i have a P870KM with TM bios for the i7 8700k it works fine but no SLI ?? ihabe 2 1080 with 86.04.56.00.2D
  4. rainer124
  5. rainer124
    i flashed all bios version but no SLI !
    i have buy an new SLI Cable no SLI !
    it is big **** happens ? ;-)
  6. dsanke
    dsanke Notebook Consultant
    Early Z370 BIOS isn't compatible with early Pascal GOP . And Clevo didn't update their source code .
  7. dsanke
    My modified BIOS have SLI fixed for P870KM , did you try my modified BIOS ?
  8. Meaker@Sager
    Also the fitting of the cable can be loose.
  9. rainer124
    Yes That works Fine
    Many Thanks :):):):):):)
  10. rainer124
    My P870DM-G with Headpipe Mod with GTX 1070 ( GTX1070 OC 242 Watt, max 65 Degree )
    and P870KM
    I am still working on the modification of the headpipe for the 2x 1080 in the 870km
    Danishblunt likes this.
