Flash bios 2060 full powered on max Q model
Discussion in 'HP' started by becham2382, Jan 5, 2021.
  1. becham2382
    becham2382 Newbie
    hi everyone, first of all let introduce myself, I'm new on the forum, happy to be here!☺️
    I have the following notebook with graphics card rtx 2060 max Q
    https://support.hp.com/it-it/document/c06679124
    I want flash the bios of the rtx 2060 taked by hp omen 15 for increase voltage, frequencies and performances. Do you think it is possibile without problems? Advices? Many thanks in advance
  2. becham2382
    becham2382 Newbie
    Hi, today I tried to flash a bios from hp Omen 15 using patched version of nvflash. Unfortunately the flashing operation failed, the program did not pass the ID detection. Its happened to anyone?
    The procedure that I followed after maked a backup of my actual bios and disabled a card by device section is this:
    1 In the folder I have put nvflash patched with a Omen's card bios.
    2 after disabled the lockout with command: nvflash64 --protectoff (operation done)
    3 I have launched the flash command: nvflash64 -6 new.rom
    in the cmd window have had this message:
    I think there are some protection or other stuff that block the writing of new bios.
    Any help is appreciate thanks
    EDIT
    After many research on google, have found a command in nvflash for force flash over a different device ID.
    Command is: nvflash -4 -5 -6 file.rom
    The question is...
    In case of brick for any problems, Can I reflash my backup default bios and restore? In case of brick, theorically the intel inbuild graphic must work.. right?
    Thanks in advance
