Fixing the M11x weak hinge creaking/cracking problem. Screen opened!
Discussion in 'Alienware M11x' started by jonjonk, Jul 23, 2010.
M11x: Does your hinge make creaking/cracking sounds? Do you have a weak hinge that moves around?
  1. M11x R1: I do not have any of those problems.
    30 vote(s)
    19.0%
  2. M11x R1: I have both problems, and my hinge broke at least once.
    64 vote(s)
    40.5%
  3. M11x R2: I do not have any of those problems.
    44 vote(s)
    27.8%
  4. M11x R2: I have both problems, and my hinge broke at least once
    20 vote(s)
    12.7%
  1. jonjonk
    jonjonk Notebook Ninja
    :) DO NOT ATTEMPT THIS IF YOU STILL HAVE WARRANTY! ALWAYS CALL DELL!!! :)
    update: The screw cap on both sides of the hinge bar(as can be seen from the 3rd and 4th picture) is on too tight. If you can loosen it a little, it will significantly prolong the hinge life and enforce less wear and tear to the hinge support on the display section.
    Yep, that's right. After being fed up with replacing the screen over and OVER due to it being weak, I have had enough. After the Dell rep replaced my screen, I asked him if it was OK for me to keep the old monitor so that I could find the source of the problem. Although he initially disagreed, I plead and plead until he finally gave in and gave me the broken screen (I guess it's my lucky day!).
    After opening the screen by force (since it was not bound by glue, it was a rather easy thing to do), I discovered a shocking revelation...it's almost the exact same problem found on the previous generation M15! Check out these photos:
    Below is what a none broken screw support looks like:
    Below is what a broken screw support looks like:
    In short, the plastic that held the screws in place gave away and broke. If Dell only made the support a little more thicker, this wouldn't have been a problem at all.
    All you have to do to fix the problem is to super glue the screws and the metal plate back on! To get a better idea of how to fix this issue, please watch this video on how this guy fixed his M15x hinge. YouTube - Alienware Area-51 M15X Case Cracking Repair
  2. slickie88
    slickie88 Master of Puppets
    +1
    Great work!!
  3. Arak-Nafein
    Arak-Nafein Notebook Consultant
    Very nice work.
    For shame, Dell. You didn't learn from the M15x?
  4. looking4pftnb
    looking4pftnb Notebook Consultant
    good find.
    So..people must be willing to solder their screen on a 1K laptop?? haha...it's like i'm paying money to do my own labor.
    By the way, even if you are new at soldering. shouldn't be difficult since you are not soldering a piece of wire onto a circuit board. Your soldering point is huge, so all you have to do is ...solder away :)
  5. jonjonk
    I know, it's ridiculous. I don't see how this problem happens mainly on the M11x. The new M15x and M17x all have the same hinge designs. I guess it's a screen weight vs hinge strength issue.
  6. ACHlLLES
    ACHlLLES Notebook Virtuoso
    Not saying you will, but just make sure you don't get charged for the part.
    When parts exchange only gets issued, Dell makes invoice initially, then it gets credited back when the part is sent back.
    I know this was not parts exchange since it was sent to a field tech contractors, but just make sure you don't get charged for it.
  7. tk112190
    tk112190 Notebook Consultant
    I think Dell should immediately hire you. Obama should give you a medal of honor. And Lindsay Lohan should kiss your feet.
    Good work!
    +1 rep
  8. hikarate
    hikarate Notebook Consultant
    Well I definitely don't have tools to solder or whatever, I thought that's what I paid Dell for...
  9. looking4pftnb
    Apparently they want to share with you the cost of fixing the hinge :p//
  10. Vallejo
    Vallejo Notebook Consultant
    Even if I dont have the hinge issue, nice contribution ;)
    EDIT (DD/MM/YY) 01/08/10: Now I got the "Keyboard touching the screen" issue and my hinge is craking...
Similar Threads - Fixing M11x weak
  1. JCordero31
    339
  2. Maxware79
    238
