Fix lag on Gkeys/Macro-keys?
Discussion in 'Gigabyte and Aorus' started by Gilles.of.Augustine, Jul 22, 2019.
  1. Gilles.of.Augustine
    Gilles.of.Augustine Newbie
    I have an Aero 15, with the 5 G-keys down the left side of the keyboard. When I create macros for them, they're surprisingly laggy. For instance, binding a key to an "m" keypress doesn't act like hitting the actual "m" key. Tapping it repeatedly will cause an "m" keypress to occur only once every second or so, and holding down the key often doesn't result in "mmmmmmmmmmmm" happening. This makes the macro keys useless for video games, because any important function I bind them takes half a second to process, meaning I can't respond quickly in-game.
    I've been using the AorusFusion software for the macros.
    Is there a way to fix this? I've tried every combination of No Delay / Fixed Delay / Auto Delay & Execute Once / Loop Mode / FRE Mode, and nothing helps. Is there a hardware limitation here? Do I need to use different macro software? CAN I use different macro software?
    Any help at all would be appreciated.
    System Info:
    Computer Information:
    Manufacturer: GIGABYTE
    Model: X7Y7
    Form Factor: Laptop
    No Touch Input Detected
    Processor Information:
    CPU Vendor: GenuineIntel
    CPU Brand: Intel(R) Core(TM) i7-7820HK CPU @ 2.90GHz
    CPU Family: 0x6
    CPU Model: 0x9e
    CPU Stepping: 0x9
    CPU Type: 0x0
    Speed: 2904 Mhz
    8 logical processors
    4 physical processors
    HyperThreading: Supported
    FCMOV: Supported
    SSE2: Supported
    SSE3: Supported
    SSSE3: Supported
    SSE4a: Unsupported
    SSE41: Supported
    SSE42: Supported
    AES: Supported
    AVX: Supported
    CMPXCHG16B: Supported
    LAHF/SAHF: Supported
    PrefetchW: Unsupported
    Operating System Version:
    Windows 10 (64 bit)
    NTFS: Supported
    Video Card:
    Driver: NVIDIA GeForce GTX 1080
    DirectX Driver Name: nvldumd.dll
    Driver Version: 26.21.14.3136
    DirectX Driver Version: 26.21.14.3136
    Driver Date: 7 3 2019
    OpenGL Version: 4.6
    Desktop Color Depth: 32 bits per pixel
    Monitor Refresh Rate: 60 Hz
    DirectX Card: NVIDIA GeForce GTX 1080
    VendorID: 0x10de
    DeviceID: 0x1be0
    Revision: 0xa1
    Number of Monitors: 1
    Number of Logical Video Cards: 1
    No SLI or Crossfire Detected
    Primary Display Resolution: 1920 x 1080
    Desktop Resolution: 1920 x 1080
    Primary Display Size: 15.04" x 8.43" (17.20" diag)
    38.2cm x 21.4cm (43.7cm diag)
    Primary Bus: PCI Express 16x
    Primary VRAM: 8191 MB
    Supported MSAA Modes: 2x 4x 8x
    Sound card:
    Audio device: Speakers (Realtek High Definition Audio)
    Memory:
    RAM: 32713 Mb
    Miscellaneous:
    UI Language: English
    Media Type: Undetermined
    Total Hard Disk Space Available: 1426728 Mb
    Largest Free Hard Disk Block: 665728 Mb
    OS Install Date: Dec 31 1969
    Game Controller: None detected
    VR Headset: None detected
