Fix for the "ERROR: MXM Structure not found or invalid" POST message
Discussion in 'Hardware Components and Aftermarket Upgrades' started by thx1137, Jan 7, 2010.
  1. thx1137
    thx1137 Newbie
    Hello everyone.
    I have a partial solution for you who want to upgrade an MXM graphics and you suffer from the infamous "ERROR: MXM Structure not found or invalid.
    Reflash MXM ROM or add MXM Structure and associated callbacks to SBIOS!
    POST will be halted for 30 seconds and performance will be limited to
    balanced performance mode until this is resolved..."
    The most annoying thing is the periodical pc-speaker beeping. You can live with the 30 second timeout, the increased performance is worth it. Beeping can be removed quite easily.
    Here is my thought process how I managed to remove it:
    After revealing the fact that the "MXM Structure..." string is stored in the video bios, it was clear that the code causing this must be stored in vbios too.
    So I started to search how the pc-speaker beeps are created. After reading an article concerning this topic on GameDev.net, it was clear, that pc speaker can be controlled only by writing to a hardware port 0x61.
    I fired up Visual Studio to find out what is the opcode for the
    Code:
    out 0x61, al;
    instruction. I wrote a short test program
    Code:
    int main(int argc, char *argv[])
    	__asm
    		mov al, 0;
    		out 0x61, al;
    		mov al, 0;
        return 0;
    After stepping through the program and enabling the display of opcodes, I have seen that the opcode I am looking for is E6 61.
    I have searched the vbios for this sequnece. I have found only two occurences close together. Just like in the GameDev article. This started to look promising.
    Then I disassembled the vbios in IDA (metapc, 16-bit code). I looked at position where I found these two instructions. (That is a BINGO! How do you say this? Ah, just bingo.) The code was very similar to that in GameDev article, pushes and pops were consistent. I was sure now that this wasnt just some random sequnece of bytes.
    So I replaced the 0xE6 0x61 bytes (in both locations) with 0x90 0x90 (do this in your favorite hex editor). This is a friend of every hacker - the NOP (no operation) instruction. x86 architecture uses instructions of variable length - 0x90 0x90 are two nop instructions (to keep the vbios file length the same). You have to make sure that you have ONLY changed the instructions marked in red rectangle in the IDA disassembly screenshot below (and ONLY in this screenshot, the other screenshots are refering to other topics), because i can not guarantee that there are no other 0xE6 0x61 sequences in other nvidia bioses (for example somewhere in data segments)
    Then I resaved the vbios in Nibitor to fix the checksum, flashed the vbios with nvflash and viola!
    As we speak, I am writing this from an Amilo Xi 1546 with an NV 9600M GT 1024MB DDR2, Hynix memory chips, green PCB.
    I have also modified the performance tables as it is described in the NightWalker guide, to make the card as powerful as it should be.
    I am quite confident that this fix should work for all combinations of NVIDIA cards and notebook models, which suffer from this problem.
    I think I do not have to remind you that you have to be careful and know what you are doing while performing this hack, otherwise you can brick your graphics card.
    The next challenge is to remove the 30 sec waiting time completely. I will look into it, if I am bored. Or you - dear readers, can (now that you know the general idea) fix it and share the solution with the world, to demonstrate that we will not just shell out another $1000 just to get better graphics in our notebooks.
    Update on the complete nag screen removal:
    It seems a bit more difficult than I first thought. Lots of references to the data segment are not resolved by IDA, and to this date I was not able to find the loop which gets repeated 30 times and calls the PC speaker code.
    As a nice side effect though, I found a place in the vbios code which tells what is the MXM revision of the card. Switch to IDA disassembly view and search for immediate value 0x5F80. Search will yield few int 0x15 calls which are used to query some MXM capabilities. One should look like this
    Click on the Jump to xref icon in this window. In the xrefs, find a location which looks like this
    The immediate value in the cl register tells you the revision. 10h = 1.0, 20h = 2.0, 21h = 2.1, etc.
    reylby likes this.
  2. Apsik
    Apsik Newbie
  3. mdwfeuer
    mdwfeuer Newbie
    hello i am german :))
    can you give me and put the vbios to my email address, please for the 9600 GS Nvidia card
  4. niffcreature
    niffcreature ex computer dyke
    what the heck you guys? is this how you to respond to something you dont understand? did you even read it??? :mad:
  5. Egypt
    Egypt Newbie
    thanks a lot but the problem is not with the Bios change, your VGA Card and it's gonna work perfect .. .... regards
