Fit 2.6mm mountless panels into older laptops that use 3.2mm panels with
Discussion in 'Sager and Clevo' started by djsubtronic, Jul 16, 2019.
  1. djsubtronic
    djsubtronic Notebook Evangelist
    As the title says, is there any way to fit the new style 2.6mm mountless panels into older laptops that use the older 3.2mm panels with the four mounts?
  2. Meaker@Sager
    Double sided foam tape would work physically.
    djsubtronic likes this.
  3. djsubtronic
    So are these screens usually fixed in place with tape/glue in the laptops that come with them?
  4. joluke
    joluke Notebook Deity
    I'd say its screwed to the back panel plastic, not glued
  5. djsubtronic
    But they dont have screw mounts.
  6. joluke
  7. Meaker@Sager
    Machines can have metal frames that fit round.
