Fingerprint reader not working
Discussion in 'HP' started by mo`, Aug 1, 2011.
  1. mo`
    mo` Notebook Enthusiast
    Hey guys I could really use some help. My fingerprint reader is no longer working, I'm not sure what happened because it just stopped a few hours ago out of no where when it was working just fine.
    When I swipe my finger the digital persona software doesn't come up and at the windows login screen it says reader not detected.
    I actually think that the hardware of the fingerprint reader might be broken because device manager DOES NOT have a section called "personaly identification software" which is what I found to be the section that the fingerprint reader is suppose to be under.
    Can someone PLEASE help me, I use the fingerprint reader ALL the time.
    EDIT: Here is an image of the error I get:
    EDIT: Got it fixed
  2. mo`
    Incase someone does a search on this forum and is having the same problem:
    Fingerprint reader [Solved]
  3. vanhalenfanrob
    vanhalenfanrob Newbie
    i did both those things and mine is still not working, it happened when i updated the simplpass software, i tried to install previous version and it still doesnt work
  4. Izagaia
    Izagaia Notebook Evangelist
    If you believe your problem exists due to a faulty software installation/upgrade, then a simple Windows System Restore (not an OS re-install) might be your best, least inconvenient, option.
    Start>Programs>Accessories>System Tools>System Restore
