Fastest cpu for GM45 chipset
Discussion in 'Hardware Components and Aftermarket Upgrades' started by Quanger, Jan 27, 2009.
  1. Quanger
    Quanger Notebook Evangelist
    Hi. I have a Lenovo T500 with a GM45 chipset. Just wondering what the fastest cpu that I can run. I believe it is the X9100. Will there be something faster or is that going to be the last c2d release until notebooks adopt i7? I currently have the P8600 which should be ok until the next year or two before upgrading processor.
  2. Commander Wolf
    Commander Wolf can i haz broadwell? Super Moderator
    For all "normal" computers, it is now the T9600 or T9800 if you can find it. If your machine has the power circuitry and thermal solution to handle 44W or 45W processors, you can go up to the X9100 or QX9300 as well.
    EDIT: I don't think the T500 can take 44W or 45W processors, but you should wait for someone with a T500 to be sure.
  3. Quanger
    hmm. I guess I will have to be patient to see. I know lenovo offers X9100 as a cpu option for their W series but not the T series.
  4. Kevin
    Kevin Egregious
    There was announced a 35w, 3.06Ghz T9900, scheduled for the Spring, but I was told that it's been canceled. The T9800 is an amazing processor, trust me.
    To answer your question, yes, I do believe that we of the GM45 family have seen our last processor refresh. I don't see Intel fitting anymorepower into the 35w threshold.
  5. Commander Wolf
    Honestly, you're going to see little to no difference in performance between the T9800 and X9100. Since your BIOS won't have the functionality to make use of the unlocked multiplier on the X9100, they are basically the same thing. You're paying a premium in price and heat for a measly 133MHz.
  6. Quanger
    T9900 @ 3.06ghz is cancelled? noooooo :(
    It will be interesting to see what i7 core will be able to offer for laptops. They cant make it power hungry so thats a huge limitation. I will probably end up getting the T9800 instead of the X9100 just because it will be a bit more forgiving with battery life.
  7. Kevin
    Kevin Egregious
    Well, I trust my source, but I will wait for an official announcement from Intel before believe him. The full bit of information I have been given is that the T9900 was just a test case, but it was decided to scrap it over the T9800 being so close in performance.
    Grain of salt...
  8. Quanger
    Hey Kevin. Just out of curiousity, where did you buy your cpu? Did it come with that customized option? I am having a bit of difficulty locating the T9800 chip other than ebay's infamous ES chips.
    What is the street price on the T9800? I wonder what the performance difference is from a P8600 (2.4ghz 3mb L2) vs T9800 (2.93 6mb L2).
    I was in the exact same spot 6years ago when I had my Centrino system. My system came with a 1.4 centrino chip which I later upgraded to a 2.0ghz chip which was quite a bit quicker.
  9. Tippey764
    Tippey764 Notebook Deity
    Whats next intel a t10000?
  10. yuio
    yuio NBR Assistive Tec. Tec.
    Intel Core i7 T920?
    I think our upgrade path is over.
