Fans running loud on P950HR
Discussion in 'Sager and Clevo' started by Shadow Cloud, Feb 11, 2019.
  1. aziraphaleUK
    aziraphaleUK Notebook Consultant
    Have you tried the rubberband method (google it). Alternatively a jewellers triangle file or a hobby drill with a very thin cutting disc to cut a slot, just make sure you tape off the surrounding areas to stop metal dust getting into machine.
    I have also removed a screw with epoxy glue, put a bit of glue on stripped head and use another screw head down, so head to head. Leave till glue has cured and then use pillars to unscrew. May work for you.
    Think the screws are M2*4L (but the service should tell you for sure)
    Service manual https://repo.palkeo.com/clevo-mirror/P95xHRx/
  2. Shadow Cloud
    Shadow Cloud Notebook Consultant
  3. jclausius
    jclausius Notebook Virtuoso
    Good luck. I hope it all works out. Keep us posted on your results!
  4. Shadow Cloud
    Okay for whatever reason. The fans have stabilized on my laptop now. Temperatures seem to hover around 60 Celsius. I just received all my Amazon order today too.... so I guess I shouldn't bother doing anything unless the fan and temperature gets out of control again?
    Edit: Spoke too soon....
  5. Meaker@Sager
    Sounds like something is not happy with the cooler be it the pipe or mounting.
  6. Shadow Cloud
    For now I'm just going to leave it the way it is. The cooling and fans are stabilized mostly. Only on sparse occasions will the fan shoot up.
  7. Meaker@Sager
    Could be the kink is causing issues as certain angles or loads.
