Fan Opening Mod
Discussion in 'Hardware Components and Aftermarket Upgrades' started by GSpark1, Sep 5, 2004.
  1. GSpark1
    GSpark1 Notebook Enthusiast
    Hi, after lapping my CPU heatsink to improve the contact between CPU and heatsink I would like to cut out the restrictive plastic fan grills that come on the bottom of the zx5000 and replace them with less restrictive chrome ones. Has anyone ever done this? Do you think my gains would be worthwhile?
    I know it would look cool... and 60mm fan grills fit perfectly in there.
    Any opinions?
    HP ZX5000
    Aquamark: 25,053
    MR9600 @ 405core/295mem
  2. brianstretch
    brianstretch Notebook Virtuoso
    I'd be concerned about vacuuming up large particles from your desk.
  3. GSpark1
    Im not so concerned about that after seeing the inside of the fan duct, im just worried about something getting intentionaly stuck in there and busting some fan blades.
    HP ZX5000
    Aquamark: 25,053
  4. mathlete2001
    mathlete2001 Notebook Deity
    To keep large objects from getting in, chicken wire might help, and it wont be very restrictive.
    GPU cooling (100°C->75°C)* Inspiron 8600 * 1.8ghz Pentium M * 128 MB Radeon 9600 Pro Turbo (337/242 -> 400/300) * 2x512 MB DDR2700 SDRAM * Aquamark 3: 24058 * 3DMark'03: 3404 * 3DMark'01 SE: 13120
  5. mathlete2001
    It probably wouldn't bust any blades, just stop the fan and burn out the motor, which is just as bad i guess. I don't think it would have any functional advantage, but I'm sure it would look great.
  6. GSpark1
    Now I dont think the motor would burn out just from being stalled =) what i meant was, my other box has a dual blowhole mod on the top for H20 Radiator and my friends at lan party's like to grind cheese balls and pretzels in them, needless to say one of the fans is down 2 blades. Its really bad because they are Tornadoes and make an incredible ammount of noise + vibration from the uneven fan (2 blades gone)
    HP ZX5000
    Aquamark: 25,053
