Fan control utility
Discussion in 'Acer' started by trandoanhung1991, Nov 26, 2010.
  1. Danja
    Danja Notebook Evangelist
    I have another question. I played around some with the offsets and discovered that a value of 1 in #94 produces a nice, gentle, barely audible hum and keeps my temps around 50 C when idling/surfing the net/watching Youtube. Is there a way to force this fan value if CPU & GPU temps are under 55 C, and then let the BIOS take over when I'm gaming and break the threshold?
  2. trandoanhung1991
    trandoanhung1991 Notebook Guru
    Absolutely. What you need to do is to open up ACFanControl.ini. Find the lines named ActiveMode, change that to 3. Then, change the following lines:
    ManModeControl=0
    BiosAtManMode= (your value at offset 85)
    ManFanSpeed=1 (obviously)
    Then change then lines ManModeExit=55 and SmartModeExit=55. You're done.
    Note: I'm not sure whether the program will revert back to manual mode. Gotta test it.
  3. outSSIDer
    outSSIDer Newbie
    Please help me :)
    My laptop is aspire 5715z and i have upgraded the cpu to t9300
    Although i have underclocked and undervolted to 600MHz :D
    the fan is almost always on. Temp never exceeds 35C ! It's stupid :rolleyes:
    Thank You!
  4. trandoanhung1991
    Can you please open Acfancontrol.ini and change the line to ActiveMode=0?
    And then, take the ss again? ^_^
  5. outSSIDer
    outSSIDer Newbie
    Thank You!
    Here you are, the new screenshots
    I just deleted the // in front of ActiveMode
    do i have to change anything else?
  6. outSSIDer
    outSSIDer Newbie
    I think i did it correct now :D
  7. trandoanhung1991
    Please also provide temps too. It'll help a lot:D
  8. outSSIDer
    outSSIDer Newbie
    Temps reported from RMClock :
    for EC1 600MHz no fan ( it last's only for ~1min before it kicks in again) 33C
    for EC2 2500MHz +2 levels from EC1 ( i can notice a clear loud change as the temp rises : it's 52C ( it doesn't get any hotter)
    But when i used to use throttlestop it reported higher temps! :(
    How can i get accurate temps? ( realtemp, coretemp )
  9. trandoanhung1991
    You can use something like CPUID or HWMonitor.
  10. gabosama
    gabosama Newbie
    Do you know if this utility works on the AS5750 (I3-2310m)? Thanks
