Fan control utility
Discussion in 'Alienware 17 and M17x' started by Mechanized Menace, Jun 2, 2010.
  1. Mechanized Menace
    Mechanized Menace Lost in the MYST
    Is there one that will work on the m17x R2 I havent found one I would just like to control the fan speeds. anyone know where i can find one Speedfan, rivatuner didnt work
  2. airplaneman
    airplaneman Notebook Deity
    Google "SpeedFan Download" to download it, but that won't work. I don't believe there is a fan controller for laptops.
  3. akluin
    akluin Notebook Guru
    There isn't soft to do that.
  4. debaucher
    debaucher Notebook Deity
    Unfortunately since i8kfangui is no longer in development there is no real way to control your fanspeeds on laptops.
    I used to use that program on my Inspiron E1705 and it was the best (actually kept that thing running despite the graphic card problems that plagued that line for a long time)
    So, unless he decides to go back in to developing the program (not likely) we are SOL
    D.
  5. BatBoy
    BatBoy Notebook Nobel Laureate
    The 17x has more than adequate cooling. I wouldn't worry much about it. Just be sure to allow for unrestricted air flow to the bottom of the system and you will be fine.
