fan clevo p377sm-a
Discussion in 'Sager and Clevo' started by Fabio Lucas Dos Santos, Mar 1, 2021.
  1. Fabio Lucas Dos Santos
    Fabio Lucas Dos Santos Newbie
    I have a clevo p377sm-a. with an i7 4940mx + gtx msi 1070.
    but the gpu2 fan doesn't work, is there any way to make it work without a gpu2?
  2. Meaker@Sager
    Not without playing with the firmware I think or making some sort of wire mod from the first slot.
  3. Fabio Lucas Dos Santos
    if you put the fan wire on gpu 2, will the two fans not work at maximum?
  4. Meaker@Sager
    If you power them off one connector supply you'll burn the fan circuit.
